smoke from oil cap?
Old Jun 5, 2006 | 11:30 AM
dub.ya.es.SICK's Avatar
Default smoke from oil cap?
I dont know if this is bad or normal, but I installed a breather a week ago and it has smoke coming out of it with engine running, not staining my hood very much but it intensifies with rpm, why/
am I in for trouble?
Old Jun 5, 2006 | 02:25 PM
nothing come on techs!?
Old Jun 5, 2006 | 03:20 PM
BLKWS.6's Avatar
Are you running a PCV as well? If you are running a PCV as well, this is indicative of excess blowby, if you are NOT running a PCV and just traight breathers, its normal, its just an avg. amount of blowby, all cars have it.
Old Jun 5, 2006 | 05:08 PM
Ωmega's Avatar
I run a breather and it smokes. It tends to slow down after the engine is warm, but it still does, whether its hot or cold out.
Old Jun 5, 2006 | 08:07 PM
BLKWS.6's Avatar
^Normal
Old Jun 5, 2006 | 09:38 PM
bg-sdpc's Avatar
LS1TECH & Trucks Sponsor
When you install a valve cover breather your evacuation system is no longer sealed so the PCV will not work correctly and you will see smoke from the breather.
Old Jun 5, 2006 | 10:02 PM
Ωmega's Avatar
Originally Posted by Stanger88
^Normal
Yup, nothin to worry about! Then again, he hasnt responded to whether or not he is running a breather or not
Old Jun 5, 2006 | 11:45 PM
BLKWS.6's Avatar
NO, you will suck air through the motor, it will go in the breather and out the PCV into the intake. If you are blowing smoke OUT the breather then you have more blowby than the PCV can handle. I took a look at mine today, (breather in one, PCV in the other) and saw no smoke, nor is the breather medium oily or the hood/strut brace directly above it.
Old Jun 6, 2006 | 12:05 AM
Z28LS1camaroguy's Avatar
what kind of breather are you runnin??? i got a edelbrock or some brand name that is metal on top and on the bottom has holes, with a filter inside of it. got it from autozone and thinkin about buyin one from PFYC.com or speed inc.
Old Jun 6, 2006 | 10:34 AM
breather equipped so normal?
