Picking Roller Rockers.
Old Jun 5, 2006 | 11:44 AM
Jordan S.'s Avatar
Default Picking Roller Rockers.
Right now I'm looking at buying some 1.8 or 1.8 ratio rockers.
I'm either looking at Pro Magnums 1.8's or Harland 1.8's. I'm not sure which to get. I read you have to use the valve cover spracers on the pro magnums and the harlands just bolt up.
I dont want to put a cam in the car for a while just something to give a little more power. Already did LT's, ORY, Pulley, Lid, and all the bolt ons. Need a little more.
If I do get a cam I want one that sounds completely stock. Are there any sleeper cams that make good power?
Old Jun 5, 2006 | 12:02 PM
Jordan S.'s Avatar
I'm starting to look more to one of Thunders sleeper cams.
Old Jun 5, 2006 | 01:43 PM
Nasty N8's Avatar
There are alot of good power sleeper cams. If not use the Harland Sharp rockers they are very easy to install and will fit without spacers.
Nate
Old Jun 5, 2006 | 05:24 PM
bluehawk2's Avatar
Where is the best price on the Harland Sharp rockers? Also are those shaft mounted rockers?? Also looking to go the 1.8 route
Old Jun 5, 2006 | 05:42 PM
bluehawk2's Avatar
Also do we need to get adjustable Rockers??
Old Jun 5, 2006 | 06:40 PM
heavymetals's Avatar
Check these:
http://www.powerandperformancenews.c...y_Code=SHFTMRA
Adjustable too!
I have them and they work very well.
Old Jun 12, 2006 | 03:05 PM
Nasty N8's Avatar
You should not need adjustable rockers unless you are going solid roller or a very odd setup.
Harlands come in 1.7 and 1.8 and are a direct replacment shaft style. We sell them for $350 a set.
Nate
Old Jun 13, 2006 | 10:08 PM
tkz28's Avatar
you dont need those shaft rockers unless your making BIG power and even then you dont 'really' need them
