where is teh crank sensor
Old Jun 5, 2006 | 12:19 PM
DaBigJC's Avatar
Default where is teh crank sensor
does any1 know where the crank shaft position sensor is located.
i know it is near the starter.
there is a sensor right under the starter going into the oil pan but it may be the oil sensor.
this sensor goes every year.
i have had it replaced about 4 times.
figured i'd try for myself this time if i could.
any help is aprecated.
Old Jun 5, 2006 | 12:23 PM
DAPSUPRSLO's Avatar
Yes, it's right over top of the starter on the block, not underneath on the oil pan. Not sure but I think you're going to have to remove the starter to get it out if you need to. It's reall easy though. Good luck!
Old Jun 5, 2006 | 12:24 PM
Quickin's Avatar
So whats the sensor that goes in near the bottom of the oil pan on the passengers side?
Old Jun 5, 2006 | 12:37 PM
bigpappasz28's Avatar
that sensor is for the oil level sensor
Old Jun 5, 2006 | 01:46 PM
DAPSUPRSLO's Avatar
What he said
Old Jun 5, 2006 | 01:56 PM
REDWS6ROCKET's Avatar
yes you need to take the bolts out of the starter and let it hang to get to the crank sensor.
Old Jun 5, 2006 | 01:57 PM
DaBigJC's Avatar
ok, looking past the starter i think i saw the right1. lil (looks like a 10 mm bolt holding down a tab that holds the sensor in?
also to take the starter out is it just those two bolts going upward from the bottom?
Old Jun 5, 2006 | 02:00 PM
DAPSUPRSLO's Avatar
Yep, just one 10mm bolt that holds it in. The two bolts go in from the bottom and that's all that's needed. Just be carefull of the wires going to the starter selonoid and not to tear them.
