Best Lifter for a Solid Roller?
Old Jun 7, 2006 | 05:40 PM
SlickVert's Avatar
Default Best Lifter for a Solid Roller?
I have ET 215 and thinking about going street/strip roller cam with Jesel rockers.
What do you think is the best roller lift for a LS1?
Bob
Old Jun 8, 2006 | 07:03 PM
SlickVert's Avatar
What do you think about the Isky solid lifters?
Old Jun 8, 2006 | 09:44 PM
Awesomeperfmachine's Avatar
The BEST lifters are Jesel's - no question. However, they are expensive and probably overkill for a street/strip car The Isky's you mentioned are a very good choice. Isky makes great products! Hope this helps...
Old Jun 9, 2006 | 01:14 AM
camrsz's Avatar
crower also makes some nice solid lifters I have a set.
Old Jun 9, 2006 | 08:58 AM
Cstraub's Avatar
Morels...
Old Jun 9, 2006 | 09:57 AM
SlickVert's Avatar
Do like the one that use the stock plastic cups or a ones with a cross bridge?
What Solid lifter should I stay away from?
Bob
Old Jun 9, 2006 | 11:39 AM
Cstraub's Avatar
Morels are a drop in. Thunder Racing stocks them I belive.
Old Jun 9, 2006 | 12:04 PM
ProdriveMS's Avatar
The BEST lifters are LSM keyed lifters. Made from tool steel, with an integral keyway, they are 5% lighter and much stronger than the Jesels. But they are very expensive- definitely overkill for the street.
Al
Old Jun 9, 2006 | 04:11 PM
DavidNJ's Avatar
Originally Posted by ProdriveMS
The BEST lifters are LSM keyed lifters. Made from tool steel, with an integral keyway, they are 5% lighter and much stronger than the Jesels. But they are very expensive definitely overkill for the street.
Al
Isn't that a .937"? Can an LS1 block handle that bushing? Does the .850" wheel change the effective tappet lift?
Oh, and how much are the lifters and pushings?
Thanks,
David
http://www.lsmeng.com/Lifters.html
Old Jun 9, 2006 | 04:17 PM
ProdriveMS's Avatar
That's right .937" diameter. The block can handle the bushing; we outfit LS blocks with them all the time. A new cam will have to be ground for the .850 wheel. Your best bet is to call for pricing as I can't post it here. Ask for me or Steve Jr.
Al
Old Jun 9, 2006 | 05:33 PM
I was thinking direct replacement drop in when I posted about the Jesels, they make a set that will work with the factory plastic "lifter tray"(LSM may as well...)
I agree with Al that the best all out set - up would utilize a .937 keyed lifter and a block prepared with bronze bushings. Again agreeing with Al the block will definitely handle the bushing, I've done a C5R with the Jesel setup.
I guess I put my foot in my mouth saying that Jesels were the "BEST", huh?? I probably really offended Al . Forgive me. Lighter and stronger is definitely better!! I kind of forgot about LSM, but they definitely do top notch work and have some of the best products out there. I've seen some of it firsthand!
Old Jun 10, 2006 | 02:20 PM
427's Avatar
427
The Jesel lifter has proven itself a very durable lifter in the LS engine, and would be my first choice if price was not a problem. The Morel seems like a good part as I sit here in Newark airport heading home after driving the Power tour with solid roller engine in my Nova with powerglide trans and 4.33 rear gears. I did break a rocker coming in to Harrisburg, but the lifters ran perfect.
Kurt
Old Jun 10, 2006 | 05:46 PM
SMKN TA 95's Avatar
When I talked to Billy (engine quote guy) at W2W last week, he recomended the Morel's as they have had great luck with them. He did say for an all out no expense spared motor, go with the Jesels.
I have been looking into the Crower LS1 series solid roller lifters with the HIPPO oiling option. These have a tie bar and totally removes the plastic lifter cups from what I have been told.
Has anyone used these? Kurt?
Old Jun 10, 2006 | 09:55 PM
427's Avatar
427
Crower has great quality parts that we use often in the gen1 engines with great results. That said, I would not put a tie-bar lifter in if there was an alternative. If you don't like the plastic guides, Jesel makes a metal direct replacement lifter guide for the LS series engine (requires some clearance machining on LS2 block).
Kurt
Old Jun 11, 2006 | 12:42 PM
CamKing's Avatar
If you are going to increase the spring pressure, make sure you go with a lifter that pressure oils the needles on the roller.
Unlike race engines, street engines spend a lot of time at lower rpm's where there isn't enough splash oil to keep the rollers well lubricated.
Old Jun 11, 2006 | 02:28 PM
SlickVert's Avatar
Good advise!
What lifts would fit ET 215 heads and still have pressure oil to the rollers?
Bob
Old Jun 11, 2006 | 02:48 PM
CamKing's Avatar
Originally Posted by SlickVert
Good advise!
Bob
I believe both Isky, Crower, and Jesel offer pressure oiling.
As far as I know the Morel's don't have pressure oiling.
Old Jun 13, 2006 | 03:29 AM
camrsz's Avatar
Kurt
Why do you not like the tie bar for the lsx engine. Do you think the factory cups with a drop in solid lifter is better the the crowers with a tie bar?
Old Jun 13, 2006 | 08:55 AM
427's Avatar
427
GM does not use tie-bar lifters because of durability and the extra weight you carry on every cycle. If my choice was the Morel lifter with the factory guide or a tie-bar lifter set, I would chose the Morel/factory guide.
Kurt
Old Jun 13, 2006 | 03:51 PM
Cstraub's Avatar
Morel actually came out with pressure fed rollers in the 80's for the Indy cars in the lifters they produced then. It was a bearingless lifter.
They do offer a pressure fed lifter both to the bearings on the roller and the face of the cam. The LS1 solid in this series is not done yet.
