ms3 vs g5x3
Old Jun 9, 2006 | 10:59 AM
c5_ls1_6spd's Avatar
Default ms3 vs g5x3
which cam is better for ported unmilled ls6 heads?
Old Jun 9, 2006 | 03:51 PM
z28misfit's Avatar
Your guess is as good as mine. Call Texas-Speed up and see what they say about the MS3.Then call LGmotorsports on the G5X3. LG can be alittle rood though.
Old Jun 9, 2006 | 06:22 PM
SVT THIS's Avatar
Depends on your goals really. Plan on spraying at all? *I believe* the MS3 is larger than the G5X3 so you will probably need a slightly larger stall. TSP also has a new cam out called the MS4, similar specs with a lot more lift. That should make really good power as well.
However, I'll tell you to get the TRex and a 4400 stall and win every race you're in
