TC and Cam, Hand in Hand?
Whether you NEED a TC or not is dependent on what cam you are planning to get. In general, higher duration cams trade low RPM torque for high RPM torque and peak horsepower. As such, the higher the cam duration, the more you will need to "skip" the lower RPM's. Cam durations below 220 or so don't need one (use 2500-3000 RPM stall if you get TC). In the 220's it is a good idea (use 3000-3500). In the 230's or above it is basically required due the loss of low-end torque and the extension of the powerband (use 3500 plus).
Regarding Stall Torque Ratio's (STR), there are more in-depth discussions available but, generally, the higher the STR the more torque you get off the line and the "tighter" or less rev-happy the converter feels on the street (requires more traction to take advantage of and is usually less efficient on the high end). The higher the STR the less torque off the line and the "looser" or more rev-happy the converter feels on street (requires less traction so it is easier to control tire spin and is usually more efficient at the high end).
All that said, you SHOULD have a higher stall TC period, even without a cam. Some the the converter manufacturers have good selection info online or you can talk to them or our sponsors to help pick the right one. You can see my sig for a cam/TC combo that I am happy with.
Steve You need to match your TC shift extentions to the cam's powerband, otherwise if you extensions are too high; you loose valuable usable power, if they are too low; then you have to wait till you reach power making range and you are waisting valuable time.
So the balance falls in the cam power range amongst other things.
I would get nothing less than a 3500 stall on a STOCK motor. That will work awesome for the stock motor, and, it will give you some good room to play with if you do decide to get a cam. Any of the "big" cams (MS3, MS4, G5X4, TRex, F14) will need a 4000 or higher.
