Where to get a Z06 cam
i think that Scoggin-Dickey (SDPC) would probably have one
http://www.sdpc2000.com/catalog/2720...S1-Engines.htm
LS6 Z06 Camshaft Kit, for 1999-02 LS1 Engines
The SDPC LS6 Camshaft Kit makes your cam swap easy and painless. We include the GM LS6 camshaft (204/218 dur @ 0.050 and 0.550/0.550 lift), SD1423 valve spring kit with titanium retainers, Manley pushrods (7.450), Rollmaster double roller timing set plus all necessary gasket and seals and a new balancer bolt.
Note: The pushrods used in this kit are intended for use with LS1 heads only, Different length needed for LS6 heads. The block and LS1 heads must have factory deck surfaces. If the heads or blocks have been milled, the pushrods will be too long. If your heads or block have been modified, please call for assistance.
