View Poll Results: Which oil are you Using in your Ls1
Mobil 1 5w-30
30.96%
Mobil 1 0w-40
4.54%
Mobil 1 5w-40
3.24%
Mobil 1 10w-30
18.64%
Royal Purple 5w-30
6.32%
Royal purple 40
2.11%
German Castrol 0w-30
13.78%
Castrol Syntec 5w-30
3.08%
Castrol Syntec 10w-30
3.89%
Other such as amsoil etc
13.45%
Voters: 617. You may not vote on this poll
POLL what type of oil are LS1 owners using??????
Old Jul 13, 2006 | 03:51 PM
  #101
black01_WS6's Avatar
running royal purple 10W40. I have a lot of miles and this oil is working great, also not burning as much as the M1 would.
Would use the German castrol but couldn't find any around me.
Old Jul 13, 2006 | 07:16 PM
  #102
Eatinstang4life's Avatar
I use bulk pennzoil 10w30 since I work at a quik lube place and change my oil when ever I want, to me oil is oil just make sure you check your level. No point of buying the expensive synthetics too me just my opinion, oil serves as one perpose, lubrication. I have tried all oils at my work and could not tell a difference at all between any of them even the synthetics.
Old Jul 14, 2006 | 11:31 AM
  #103
Nick04's Avatar
LS1Tech Sponsor
at work mostly our street cars run Royal Purple, and race cars run Red Line.
Old Jul 14, 2006 | 11:40 AM
  #104
speed_demon24's Avatar
Oil does just more than lubricate the parts.
Old Jul 14, 2006 | 01:18 PM
  #105
mccollum_007's Avatar
I use regular Pennzoil 10w-30 as well, prolly gonna switch to synthetic next oil change tho
Old Jul 14, 2006 | 06:03 PM
  #106
SSRZ28's Avatar
what happened to heat exchange, protection.... does more than just lubes
Old Jul 14, 2006 | 06:34 PM
  #107
Yes I know but its main purpose is to lubtricate. I understand that oil surves other purposes also. I have worked in the quik lube business for over 4 years, and I can tell you here is not much difference between bulk oils ans synthetics but the bottle and the price, this new mobil7500 stuff is the biggest con I have ever seen, what if your car burns oil duh. If your car burns oil it doesnt matter what kind of oil you use it will still burn the oil even if it is thicker weight viscosity. Just change you oil about every 3000 miles and check the level in between changes and you should be good.
Old Jul 16, 2006 | 01:27 AM
  #108
ls1wfo's Avatar
Default The ultimate oil for LS-1
Ok chillin, listen up. ( " SYN-LUBE FOR LIFE" ) is the absolute best & I might add ,the one & only true no bull **** 100% completely synthetic all man made with no petroleum fillers. And yes, it's expensive as hell but always remember , like my Grandfather always told me, Son, it only cost a little more to go first class and buy the BEST ! RP will ruin your seals & gaskets and start oil leaks all over the place if your engine has over 75,000 miles.We used M1 5W/30 extended life & never used a drop between changes plus it stayed pretty clean for about 7 or 8000 miles but we were trying to get rid of the slap so we tried GC 0w/30 . engine ran hotter, oil pressure dropped , noise still there but a little subdued . Go figure . Used to swear by Pure one filters but later found them to be way too restrictive. Long K&N 2006 now but still can only get 5 & 1/2 quarts in . GM said to try their EOS engine supplement to soften the piston skirt slap & wear. SYN-LUBE FOR LIFE is available on the internet . It works !!
Old Jul 16, 2006 | 05:04 PM
  #109
Bill Bowling's Avatar
Talking
Never heard of Syn-Lube. Do you have any oil analysis on a LS1?
Bill
Old Jul 19, 2006 | 06:01 PM
  #110
blue98Z's Avatar
m1 10w-30. never had any problems out of it on any of my other vehicles.
Old Jul 19, 2006 | 08:25 PM
  #111
slowpoke96z28's Avatar
Kendall GT-1 10W-30
Old Jul 20, 2006 | 08:23 PM
  #112
Mr Ed's Avatar
I have strict standards. I will only use oil manufactured by a company that is an NHRA or NASCAR sponsor. Oh wait, that's just about everybody. I just go with whatever 5W-30 is on sale. I drive my cars for 200,000+ miles and never had a problem.
Old Jul 20, 2006 | 10:17 PM
  #113
Lol just like me no reason to waist your money on expensive oil.
Old Aug 11, 2006 | 10:44 AM
  #114
Christopher Sims's Avatar
GC- better oil pressure and less noise than Mobil 5W30 or 10W30 in my car.
Old Aug 13, 2006 | 01:34 PM
  #115
Nick98Z28's Avatar
I'm suprised so many people are using mobil 1, I was using it for a little while but it was going so fast every week and a half I would have no oil left. I had to switch to castrol syntec after a friend recommending it to me and have had no complaints.
unlock the power
Old Sep 2, 2006 | 11:37 PM
  #116
Asmodeus's Avatar
Just picked up 2 more GC 0w30 oil changes and 2 more K&N filters from an Autozone on my block.
I still can't believe some people can say "oil is oil" when they have never had a single oil analysis done, or even have not likely seen data from one or tests done on oils. Guess they all have the same detergents and additives? Guess they all have the same shear strength? Guess they all have the same resistance to crush? Yeah.. whatever.. here's a 20, change my oil bitch!
Old Sep 3, 2006 | 12:45 AM
  #117
coolformula's Avatar
GC user here. I still run mobile 1 in my lt1 rightnow...but might swtich.
GC is a good oil.
