Upgrading heads for 408?
Old Jun 13, 2006 | 01:45 AM
marine02ss's Avatar
Default Upgrading heads for 408?
I want to upgrade my afr205's in my 408 like now,I am taking them off this weekend.Which heads would best suit my application?Have money in hand to buy new heads ET'S,AFR225............
Old Jun 13, 2006 | 02:56 AM
ls1juan's Avatar
Default Save Money
Hey check it out your AFR heads you have are veary and I mean veary respectable heads.In my opinion save your money and just have somebody respectable port them out.You said that you had your 408 build by LME just take those AFR heads back to them and have them port them out.I know the owner from LME I used to work with him Pacos the guy is guiness and know's what he is doing.If you did not do it when you got you'r 408 build have them put 2.08 Intake and 1.600 ex.depending on what cam you have that will be your best bet for more horse power.I'm actualy a head porter well used to be I worked at a respectable shop and know what I'm talking about know I'm in the Army and on my way to Iraq.Get back with and let me know you cam specs I got tons of more advice for you.
Old Jun 13, 2006 | 12:20 PM
marine02ss's Avatar
Well I guess I am going to AFR225 my friend is selling them to me brand new,anybody else have any suggestions or how to make them better.I plan to mill them .024 to get 62cc so I can be right at 11.60CR with a GM MLS gasket.Ill se if I can hit that 500rwhp mark
Old Jun 13, 2006 | 12:26 PM
allngn_c5's Avatar
500 rwhp should be no problem.
Old Jun 13, 2006 | 12:35 PM
xaon's Avatar
big bore or small bore 225's? I'd personally leave the 205's on there if they are big-bore 225's.
Old Jun 13, 2006 | 12:40 PM
marine02ss's Avatar
They are small bore 225 with 66cc chambers,how about some ET heads?
Old Jun 13, 2006 | 12:58 PM
xaon's Avatar
Small bore 225's are good... I really wouldn't expect to light the world on fire by swapping the heads though... what you have are already top-notch heads.
Old Jun 13, 2006 | 01:43 PM
SVT THIS's Avatar
I was looking into a set of ET 225's for my 346 (I will swap them to a 408 build next summer). I was talking to a member on here who has the ET 245s and said they are amazing on his 408. However, a 90/90 intake setup will not flow enough for those heads, he's going to use a sheetmetal intake of some kind. I would also look into a set of 1 7/8ths headers if you haven't already.
However, if you want to save the money you could probably get the AFR 205s you have now CNC'd and get some great flow numbers from them.
Old Jun 14, 2006 | 10:57 PM
marine02ss's Avatar
Well I already got the AFR 225's heads today,brand new.Next weekend Im going to go to Houston to pick up another 408 Brian at LME build for me.I told him about the heads,so we came to reason were going to mill them .018" while Im there, and go with a thinner head gasket to get .040" quench.I hear alot about quench as tight as .030" is that to close?I want to expect or assume to pick up at least 10-15hp
Old Jun 14, 2006 | 11:09 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
The 5.3s do well if ported right. Here's a thread from our SS.
https://ls1tech.com/forums/dynamometer-results-comparisons/521967-finally-got-408-grocery-getter-dyno-results.html
The AFRs would be a good choice though. Remember though that with a bigger cam you can run a bit more compression on pump gas. Just get the DRC right. Good luck.
Man you need things to go your way. You deserve a break. Keep us posteed!
Old Jun 14, 2006 | 11:15 PM
beardWS6's Avatar
SVT is right about ET 245`s. Mine outflow my 90/90 ported set-up bigtime. I`m saving to go alittle bigger to help them flow. But I wouldn`t change a thing!! Love the TRQ all threw my rpm range.
lilbuddy1587's Avatar
Instead of worrying about just your heads, I'd have your fast intake ported...
Old Jun 14, 2006 | 11:19 PM
marine02ss's Avatar
What CR did u end up with, do you know your quench?I plan to run at least 11.7CR with .030 to .035 quench like the mamofied 383.I want to hit my goal of 500rw thats it then,Ill be happy and throw the 200 shot of gas
Old Jun 15, 2006 | 11:12 PM
Phoenix 2001's Avatar
Are you selling the AFR 205's
Old Jun 18, 2006 | 06:07 PM
marine02ss's Avatar
I already sold them sorry,but I think after I switch to the 225's Im selling my 408 complete with heads and intake,I kinda wanna a 427
Old Jun 18, 2006 | 06:46 PM
cws T/A's Avatar
g0 ls7 heads next and skip to my lou 600rwhp na
Old Jun 18, 2006 | 06:57 PM
marine02ss's Avatar
Im selling then going to a LS2 based 427 with factory Ls7 heads and intake,see where that leads me to hopefully 600rwhp,whoohoo
