who makes the thickest head gaskets?
Old Jun 13, 2006 | 10:32 AM
97F1R408's Avatar
Default who makes the thickest head gaskets?
Just bought a new 408 but was intended for use with 72cc heads with comp ratio at 13.5:1 but I have allpros with 62cc dome on pistons is 10.2cc and realize this is a race gas engine but trying to keep it within reasonable limits without making it diesel. thickest Ive seen is .074 cometecs but I didnt see if that was a compressed thickness or not. Any input is appreciated or if some one is looking for head / parts trading let me know thanks, Mason
Old Jun 13, 2006 | 11:32 AM
ringram's Avatar
Ive heard & read that you may find knock worse with a thicker gasket as you lose quench.
You are probably better off doing the head swap you discuss and keep quench tight, somewhere around 0.040
Old Jun 13, 2006 | 11:48 AM
97F1R408's Avatar
thanks for the reply I have gone on diamonds site and with 62cc heads it is around 14.75:1 how many ls1's are out there running that high and what fuel are they running minimum with no problems and a good tune?
Old Jun 13, 2006 | 11:59 AM
PREDATOR-Z's Avatar
What is your DCR?
But that is definately Radicalismo, you might want to consider Meth injection too.
Old Jun 13, 2006 | 12:00 PM
SStrokerAce's Avatar
Your issue is going to be the dome clearance problems... if the dome was not made for the same combustion chamber you are running a gasket will be the least of your worries, the piston hitting the chamber of the heads will be.
Bret
Old Jun 13, 2006 | 01:15 PM
King James's Avatar
I take it this is the 408 that Only 231 was selling? If so, I was looking at buying that block but you beat me to it. I had plans on ditching the domed pistons for flat tops. Might be something worth looking into.
Old Jun 13, 2006 | 03:34 PM
97F1R408's Avatar
Yes its the same short block I guess I got it cheap enough to swap out pistons and have rebalanced or maybe they could make me a set that are the same weight ?
Old Jun 13, 2006 | 10:46 PM
67Ranger's Avatar
you could also try and have your chambers expanded on your heads, there are a few places that do that i believe.
