which rod lenght
Old Jun 14, 2006 | 12:37 PM
1936FordPU's Avatar
Default which rod lenght
on a 370" iron block?
6.100 or 6.125 with this piston....forged eagle crank, stock stroke.
http://www.flatlanderracing.com//wis...ons-sbc07.html
part number K392A3
Old Jun 14, 2006 | 07:14 PM
HeapaShifter's Avatar
I know the stock rod length in a 346 is 6.098." If you want the stock stroke I guess you'd use the same. Don't buy anything based off my answer though.
Predator Z has a 370 and he's very knowledgeable about modding engines. He'll know.
Old Jun 15, 2006 | 09:35 AM
GuitsBoy's Avatar
You can use either so long as the pistons are made to work with that length rod.
Old Jun 15, 2006 | 03:31 PM
1936FordPU's Avatar
grrrr
the piston has the option of both...I just want the piston located in the bore where it should be...Hate to order the wrong rods...
Old Jun 15, 2006 | 04:24 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I have a set of 6.2xx rods in the nitrous motor.
Old Jun 15, 2006 | 04:41 PM
GTA91's Avatar
6.2's
