243 head question
Old Jun 15, 2006 | 12:32 AM
DarkC5's Avatar
Default 243 head question
I just bought a set of 243's off of a 03 Z06 for my 00 C5. I was wondering if I should just put them on or have them ported out? I don't want any oil consumption or smoking issues and am not sure if these heads have that issue. I know that the Darts were having some problems. Anyone have any feedback? And does anyone have any refences for a good shop in the chicagoland area that does port work?
Old Jun 15, 2006 | 12:35 AM
94lt4's Avatar
My 01 243's never had an issue. If i were in your shoes, i would have them ported. Why do the same job twice? As for Chicago, I have no idea. Good luck and grats on the new heads .
Rob
Old Jun 15, 2006 | 01:49 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
LS6 heads work pretty good just cleaned up. But once again... as for porting in the chicago area...no clue. You might check with ProStockJohn.
Old Jun 15, 2006 | 09:16 AM
GuitsBoy's Avatar
Ship them to a shop that specializes in lsx work. Contact patriot or PRC.
Old Jun 15, 2006 | 10:50 AM
Gunnar@Patriot's Avatar
We can CNC port your heads, perform our 5 angle valve job, hand detail and blend the bowls, and re-assemble your heads using your parts for $600.00. Please give us a call if you have any questions.
Old Jun 15, 2006 | 02:29 PM
under pressure's Avatar
When you have the heads ported and cleaned up, is there any advantage in retaining the factory lightweight valves versus replacing them with aftermarket stainless?
Old Jun 15, 2006 | 04:09 PM
AJay's Avatar
Old Jun 15, 2006 | 05:03 PM
jlrz28's Avatar
10 Second Fun Car
Talk to TEA they are in Ohio.
