Which LSx series is iron??
Old Jun 27, 2006 | 09:07 PM
BerryWS6's Avatar
Originally Posted by License2Ill
Hoes yes I am seriously considering and even though it is a year away if not more I like to do my research early while I look around for the package and it's prices, I think it is awesome that we can get an Lq9 and bore it out later of need be or run some serious nitrous through it, for me iron is where its at, and seeing as to how well populated the Lq9 sits in all those cars it makes even more attractive.
A last question and if you don't know it's not that important, can I with a different bellhousing (I imagine at minimum) bolt on my T56 to the appropriate bellhousing? or are the newer bellhousings matched only to what could be a newer casting or boltup pattern on later T56's? rendering my older t56 completely useless.
I thought the input shafts on the transmissions were different (LS1 vs. LT1), may be wrong but I think our trans not going to work...
Old Jun 27, 2006 | 09:16 PM
jdoyle's Avatar
ya you are going to have to change some stuff to get your LT1 trans to work in the LS1 motor, diff hydraulic system and input shaft just to name 2, and youll need a new faceplate as well if im not mistaken.
id call t56rebuilds, they did my trans and its BADASS! they are a sponsor as well.
www.t56rebuilds.com
Old Jun 27, 2006 | 10:00 PM
Zick's Avatar
Originally Posted by defrag010
just a FYI, I rebuilt a pair of 6 liter heads out of a 2500 truck a week ago that were cast.
Those are the 99-00' 6L heads. 01' and later came with Alum 317s.
Old Jul 7, 2006 | 09:08 PM
1MEANGTO's Avatar
Oh and one more thing about iron whens the last time you saw a pro stock alum?
answer 1969 427 built by grumpy.
Taking to identical engines and one being alum and the other being iron. The iron motor will make more horsepower since it does not "move" around as much.
Old Jul 8, 2006 | 12:50 AM
BIG BAD BLACKSS's Avatar
The forced induction crowd seems to preffer iron on big power builds. SOme of the big name builders are talking about the blocks deforming over 800-1000 rwhp. Forgot what exactly started moving around in the block but it is a somewhat common problem at those power levels it seems. Pretty sure it had something to do with the piston rings loosing seal and the problem wasnt correctable as the block was failing.
