F13 and Nitrous?!?
Old Jun 16, 2006 | 12:55 AM
iMpoSStoR's Avatar
Lightbulb F13 and Nitrous?!?
anyone running a F13 and nitrous if so does this cam like it.. also would it be better on a 114 or 112.. thank you for any replies
Old Jun 16, 2006 | 01:01 AM
1sick'98WS6's Avatar
i dont know, havent heard of anyone running it with nitrous, i thought it was a good n.a. cam...
Old Jun 16, 2006 | 01:38 AM
iMpoSStoR's Avatar
oh.. so not a good choice with the juice?.. i thought nitrous liked cams with higher intake lift than exhaust ?
Old Jun 16, 2006 | 01:44 AM
mypoorLS1's Avatar
I thought it was the other way around but you want a bigger split. Don't need as much on the intake cause the nitrous is putting the oxygen in the motor. Needs more exhaust lobe to get it out. Maybe I'm wrong.
Old Jun 16, 2006 | 02:25 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
It is the other way around. Higher exhaust duration/lift. You really don't need a cam taylored for nitrous if you don't plan on spraying more than a 150-maybe a 175 shot. If you are going bigger you are going to want another fuel pump and some 30-42 lb injectors most likely. Don't lean your **** out man!
I would spray the F-13 by the way. Just about any cam is going to react to nitrous.
Old Jun 16, 2006 | 02:34 AM
iMpoSStoR's Avatar
yea.. the most i plan on spraying is a 125 wet.. so im not risking anything by running this cam on the bottle right ? by risking i mean like the first run or two on nitrous and kablamo..
Old Jun 16, 2006 | 02:35 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Hell no....You will see increases on the dyno and the track. Spray it!!!
Old Jun 16, 2006 | 02:50 PM
RDY2RUN's Avatar
Cool f13 and Nitrous
There is a guy on here with a f13 and a 75 shot. His sig is aint skeered I think. Over 500 rwhp with a 75 dry shot I believe. Hope this helps.
Old Jun 16, 2006 | 10:12 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Yeah man. It will be a bad motor scooter with that 125!
Old Jun 17, 2006 | 02:44 AM
Darkta's Avatar
I use to run that cam on my old car on a 114 lsa on a stalled car with 150 shot and it was crazy fast best et was 11.50 at 6000 ft elev. and 13.3 na
Old Jun 17, 2006 | 08:59 AM
prostock_bigblock's Avatar
freind of mine sprayed 150 on F13 on a 4 door holden commador and went 10.6 with 3200 stall and 3500-3600 weight.
and 11.6 N/A.
Old Jun 18, 2006 | 08:46 PM
iMpoSStoR's Avatar
so then pretty good results with the spray.. for almost dropping 2 seconds on a 150, sounds damn good to me..=)
Old Jun 18, 2006 | 09:51 PM
bowtieman81's Avatar
F13 with nitrous here. Mine is on a 112 LSA. Don't worry about it, spray it. Like said above get a cam based on your N/A goals unless you are spraying a huge shot like 250+ hp.
I am running my NOS kit at about 125 hp shot, and it pulls nice . In fact it pulls nice enough to toast my clutch, which is being fixed right now. Once broken in I will see how it does at the track.
Old Jun 18, 2006 | 10:53 PM
DSG's Avatar
DSG
I sprayed mine with a 150 shot. the cam was a 114 lsa. Car ran 6.8xx@103.xx in the 1/8th.
Cam loved the juice....
Old Jun 18, 2006 | 11:18 PM
im going with the f13 but i dont know if i will be spraying it ever. i just want the nice chop and power gains
Old Jun 19, 2006 | 01:19 AM
iMpoSStoR's Avatar
WHAT WAS YOUR TIME IN THE QUARTER DSG..you didnt run the 1/4 what would it have been more or less according to your 1/8 mile time and mph
Old Jun 19, 2006 | 10:37 AM
DuronClocker's Avatar
Should've been somewhere around 10.6-10.8 or so with that kind of 1/8
Old Jun 19, 2006 | 11:58 AM
DSG's Avatar
DSG
Correct. My best time was 10.78 @ 127.8xx. That was on my stock 10 bolt with 3.23's. It was also last summer in the Blistering heat and it rained on me right after the pass when I was going to the et shack.
My car had SOOOO much more in it. The set up I had was fun.
Old Jul 3, 2006 | 01:26 AM
NEVR2ND's Avatar
150 shot got me a 10.8 N2O and 11.8 N/A with my F13
