Feedback on Patrick G's Torquer cam.
Even with a high stall converter, a properly chosen cam (narrower LSA and smaller duration) will walk all over the typical wide LSA cam so popular on this board. Why? It's called area under the curve. When you have more torque, you'll have more hp too. With more area under the curve, the converter will flash higher, giving you a stronger 60' time and it will have higher shift extension rpm because of the added hp in the 5000-5500 rpm range.
If you want a cam that would beat the MS4, just go about 4 degrees smaller in duration, then narrow the LSA around 2 degrees, then make sure your overlap is centered over TDC or even biased somewhat to the intake side. This cam will make more area under the curve and better topend because of superior valve events, higher DCR and better positioning of overlap.
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
There is no need to compair Pat's cam to the MS4 it is common since that the MS4 (with the proper setup) will make more power above 6000 RPMS without a problem then his 224/228 cam (with the proper setup)
Again the 2 cams are for 2 different drivers, and have no business being compaired side by side.
Pat decited his goals and based his cam choice on his goals. His cam was different and was similar to the Thunder Racing T rak cam he had ran before.
That dosen't mean this is the best cam of all time, or that this cam is better then everyother cam for every different setup. However it is probally the best cam for HIS setup and goals.
As far as what someone had said earlier about the TC and this cam being better for a Auto. That is not correct. While a 6 speed car would like this cam a auto even with a large 4000+ stall will also do very well with Pats cam.
For those that need proof, look at Pats dyno compairision. The 234/238 cam made more peak power as did the T rak but not by much. So it is easy to see there are other cams that have the potential to make more peak power, again not what Pat was after.
For best area under the curve and superior top-end with the LS6 or FAST intake, you want to limit your IVC to around 46 degrees ABDC at .050", get your DCR as high as you can, then get your overlap centered over TDC or slightly biased to the intake side (for superior top-end).
235/240 .646/.600 109LSA (+1)
The DCR is 2 tenths higher than the MS4 and overlap is centered over TDC giving it superior top-end. If TSP were to try this out, they'd have a real winner on their hands.
My 224/228 110LSA cam has 6 degrees of overlap at .050".
A 234/238 114LSA cam has 8 degrees of overlap at .050" and would idle worse.
2 degrees more overlap makes for poorer idle. In this case 110LSA cam idles smoother than a 114LSA cam. Make sense?
No you just have different experience with cars and cams in LS1's. A 110 LSA with the proper tune can idle and drive very nicely.
Your basing your facts on a 110LSA on other peoples oponions and Pat is basing his facts on what he has seen first hand.
The LSA will have a effect on idle but a 110 dosen't mean the cam is a bad driveability cam. There is a lot more to it then LSA, its called overlap, read up on it sometime and then you can understand how a 110LSA can idle very well.
However, the size is also dependent on what your heads flow and the engine speed range. It is my understanding that some people have had good power--but marginal driveablity--with large cams with stock intake, tb, and heads. Some older, OEM style head big blocks also end up with very large cams.
Patrick has a strong free flowing system. He also has a head with well designed combustion chamber. And he has the compression to prove it! Then he leveraged the high lift LSK lobes. In his testing, a larger cam added negligable (~1%) peak hp, with lower power nearly everywhere else.
What was the setup the MS4 was designed for and tested--comparatively--on?
They definitely know their stuff! Surely you need a COMPARABLE dyno chart from both cams running similar mods???
So far all I've heard in this thread is it'll beat the MS4, but where are the dyno graphs for the MS4?
Now I'm not saying a MS4 will produce such a good low end, but how can anyone sit there and claim it will comparitively nothing when they have no proof and no idea what it's capable of.
MS4 specs: 239/242 .649/.610 on a 111LSA
BTW - I personally highly respect PatrickG and PredatorZ, they both really know their stuff and it's well worth reading and respecting any advice they offer.
But making assumptions based on a lack of info and then giving advice based off of it (which is what most of this thread appears to be) is IMO vey wrong and mis-leading for others.
THATS REALLY IT... IM NOT SAYING ITS NOT A GREAT CAM IM JUST SAYING FOR US DRAG RACERS THE MS4 WILL MAKE MORE POWER WHERE WE WANT IT.. AND WHEN PEOPLE TRY TO SAY A 224\228 CAM IS MORE POWERFUL THATS TOTAL BS
Guys, the cam doesn't drag on its own, it is part of an overall combo.
Gimme Patrick's car against a cam only MS4 and I will wipe the **** out of that MS4 car.(You don't mind 5K+ clutch dumps do you Patrick
)Combo, combo, combo.
The MS4 has much more potential in the PROPER combo at the track. (meaning the right supporting mods, SCR, DCR etc......)
Aside from overlap, I'm curious why you chose a traditional split as apposed to a reverse like a 230/226. Also how did you come up with the exact lift amount you ended up with? Lobe choice is the obvious answer, but why more exhaust lift than intake? Sorry if you've covered this already.
I'm personally looking at having thunder grind a 230/226 111 +0 lsa with around .6 and .605 lift. It still has 6 degrees of overlap, a nice tight lsa, and is still comparatively small to a lot of other cams. What do you think? Sorry for the slight hyhack
1. It gave me the valve events I needed (biggest reason of all).
2. My heads/intake now flow better than my exhaust (not always the case cam-only).
3. It was very important that my overlap be biased toward the intake side of TDC so my motor would carry good power past peak hp rpm. A reverse split will tend to bias your overlap to the exhaust side of TDC which will make your motor run out of breath faster after peak power.
I chose the higher-lift LSK lobes to give me more valve curtain area under the curve which would take advantage of the excellent high-lift airflow of my AFR heads.
If you are running excellent exhaust with stock heads and LS6 intake, reverse split cams make a lot of sense. In my case however, the lobes I chose made sense for my application.
Between us, I'm curious as to how the 232/234 with 5.3L PRC will react to 370 cubes and high SCR/DCR.
One thing for sure, I kinda expect that finally the TORQUER will live up to its name.
meaning "produce some torque."
Id really like to compare results to just see similarites if any.
Id really like to compare results to just see similarites if any.Right now, I just want to finish it, save for another tranny (still wainting to see how transbrakes are holding up in 4L60E), and just tune it + beak it in nicely.
