Major Oil Problem - getting closer to an answer... need help!!
You cannot determine the condition of the rings/valves, by listening to the noise, or lack of.
Leakdown should be done w/ engine hot, valves backed off.
You said: "like i said... the leakdown tester showed perfect readings.. it stayed perfectly still at the "set" position on the guage...". NO WAY is that going to be the case. Even the most meticulous prep, zero gap rings, yadda, yadda, and you will have some leakdown.
I am burning about a quart every 200 miles. However, a compression test on all 8 cylinders is right where it should be. I also ran a 13.3@108 with only a lid and chokemaster muffler on street tires. Would it run this well and with decent compression if there was a problem with the rings that allowed that much oil past?
secondly, the % loss, seriously was nothing... the guage reads in 4 zones "set", "low", "mid", and "high", meaning the amount of compression lost...
so, i dont think we did anythign wrong... but it stayed in the "set" area... obviously, when the valves were open, it would drop to 100%, but once the piston was back to tdc, it stayed in the "set" position...
Also, i've heard once that if you get a air/oil seperator, that you should take out the filter element. is that so?
If you don't know how hen pay someone to do it right.
Otherwise you'll be just chasing your own tail.
The test will point you in the right direction.
but, that doesnt answer my question... say for example, so that i'm not wasting any more time that i already waste not gettin crap done (my own damn fault), if all they cylinders test out to be fine, then what is the answer to my questions above?
i just cant see it staying in the set area of the gauge unless the gauge is fulty, or the psi was set wrong.
(not calling you a lier, please dont take it that way!)
im just saying there is some thing wrong with the test you ran.
good luck and hope you find the problem and fix it soon.
Honeslty though, i don't know how much was going in, and don't know how to tell... my buddy couldnt find the instructions booklet for it.
From your description, I can pretty much guarantee that it is the rings. Ive seen it time and time again. PCV will not burn that much oil, that quick. Worn Valve stem seals will usually burn more oil while the engine has the most vacuum. If its burning at high RPM's its rings.
So, today i'm going to pop the intake manifold off and see if there is oil on the back of teh intake vavles. If there is, well then, my answer is that the heads are allowing oil to run down the valve stems.... And new heads will be bought... we'll see.. i'll keep you posted
but back to good news for me and just1news6, i didn't get the intake off completely, because of something that was hooked to the back of it... i didnt really wanna break anything, and i couldnt tell what was hooked onto, or into it in the very back (anybody know?)... but anyhow, i got it lifted up and peeked down into the head on the first cylinder on both sides of the motor.... Well, what to say except, holy sh*t! It looked like there was a puddle of oil on the intake valve ... so i stuck a long, skinny screwdriver down in there nicely, and when i pulled it back out, there was b/w 1/8" and 1/4" of oil puddled on the back of the intake valve (around 6/32") ... thats freakin rediculous, that not only is there oil on the vavle, but with the valve closed, its freakin puddled in there.......
so, it looks like i will be going with a set of 5.3 heads, being that i'm on a very tight budget, and they should make more power than my 241 castings anyhow...
good luck man! i hope you can fix ur problem!!
