torquer v2 dyno results
Old Jun 20, 2006 | 10:02 PM
DWillTA's Avatar
Do you have any specs on the heads? Are they stock LS6 heads? Your sig says they are PRC LS6 heads. Are they the $900 heads they sale?
I say the issue is with the head porting or the DCR and SCR are not setup properly for the camshaft.
Dave
Old Jun 20, 2006 | 10:07 PM
seth webster's Avatar
Dave
Whats the DCR and SCR, and what could be done to get the heads setup properly for the camshaft??
Old Jun 20, 2006 | 10:11 PM
DWillTA's Avatar
DCR - Dynamic Compression Ratio
SCR - Static Compression Ratio
A cam that sizes wants and needs compression. Probably as high as 11.5 to 1 static, but more importantly the dynamic compression (DCR) needs to be in the 8.3 to 8.8 range depending on available octane of fuel.
Dave
Old Jun 21, 2006 | 09:15 AM
Slow00ls1T/a's Avatar
ya it is the 900 dollar ones they sell tuner also said that it threw 02 heater code didnt ask what bank it was on he said that on the first run didnt ask if it was still there on the last
Old Jun 21, 2006 | 09:50 AM
KGSloan's Avatar
i'd look to the heads first...
do a leak down and make sure everything is sealing correctly or see if the rings are overly worn (i wouldn't think so from your baseline dyno though).
did you mill the heads any, are the pistons notched for the cam??? it is possible you've made piston to valve contact which would kill your HP and TQ.
Old Jun 21, 2006 | 10:55 AM
dedge's Avatar
My torquer 2 only put down 351 rwhp on a 98 with stock heads on a dynojet. They told me the stock heads and Vigilante stall ate all my hp up. I also have the ls6 intake and a supermaxx headers with cats. Run it at the track thats where the difference will be told.
Old Jun 21, 2006 | 05:12 PM
what numbers should i make at the track
Old Jun 21, 2006 | 07:09 PM
Quik's Avatar
should be low 12s to high 11s depending on setup
Old Jun 21, 2006 | 09:40 PM
Do your heads have the extra $100 valve job and are you running cats???
A LS6 intake would prolly add about 15-20rwhp to that setup a underdrive pulley would prolly give you another 5hp.
Id just get some bolt ons, retune and dyno again and you should def make 400+ rwhp
Old Jun 22, 2006 | 07:52 PM
no extra valve job
Old Jun 23, 2006 | 08:29 AM
UltraZLS1's Avatar
Do you know your static and dynamic compression like the others have said?
My prc heads made some good numbers on an old 92k mile 98 short block. My dynamic compression is 8.6. And my cam is smaller than the torquer v2.
Get a pulley, and an ls6 intake...and then set up your dcr higher with a thinnner gasket and maybe even some milling if necessary (wasnt for me, but your cam is different) And you should see some great results
Old Jun 23, 2006 | 01:42 PM
  #32
Originally Posted by Slow00ls1T/a
no extra valve job
How long ago did you order your heads? i was talking to John at TSP today and he said that all the new LS6 heads come with the valvejob now.
Old Jun 23, 2006 | 01:56 PM
  #33
I had the option but didnt go for it
I have no idea what dcr or scr is
Old Jun 23, 2006 | 06:15 PM
  #34
UltraZLS1's Avatar
if you're heads are unmilled and you used a stock thickness gasket then your dcr and scr are most certainly going to be too low.
Old Jun 23, 2006 | 08:38 PM
  #35
DuronClocker's Avatar
5% lower readings is a lot when you're near 400rwhp...that'd put you up to around 410rwhp right there, slap on an LS6 intake, and you're looking at 430ish RWHP. I wouldn't be too worried. Like said, take it to the track. Dynos are only good for tuning, not comparing cars.
