Solid Roller Spring life???
Old Jun 20, 2006 | 08:41 PM
1999TransamWs6's Avatar
Default Solid Roller Spring life???
Was wondering what kind of spring life I could expect out of a solid roller with a 270/279 .715 lift cam with 305 closed seat pressure. MAYBE 50-100 miles weekly street miles. Im not woried about the quality idle ETC. just want to know spring life on something like this.
Old Jun 20, 2006 | 08:52 PM
383LQ4SS's Avatar
depends on the spring chosen and how its setup. There are springs out there that "should" last with a cam of that size. But they are going to be large springs with a very tall installed height. You really need aftermarket head to do this right. Stock ones are tought to fit anything over a 1.550 diameter spring. And be sure to talk to your head guy before ordering everything...a much longer valve will help out as well since you can fit a spring with a 2.000 installed height.
Do you have any more specs on the setup?
Old Jun 20, 2006 | 10:00 PM
speed_demon24's Avatar
I'm posting this for him, I know what setup hes probably going with.
Iron 408 with all forged internals
ETP 265 heats
Sheetmetal intake
+ all the drivetrain/suspension mods he already has
Old Jun 20, 2006 | 10:11 PM
383LQ4SS's Avatar
OK...well then I would talk to ETP before you get the valves and springs/retainers and let him know of the cam specs. Go big on the springs IMO. Wider and taller is better than trying to get the right pressures with a smaller shorter one that is on the edge of its capacity.
Old Jun 21, 2006 | 08:00 AM
I believe it was a 2.00 installed hieght and 1.6xx diameter. How long if you had to guess would they last if I street drove it 50 miles a week?
