Can we use CSA instead of Port Volume?
LS heads now include multiple variations of intake port entrances and different chambers and valve angles. All of this makes port volume comparisons less useful. However, the cross sectional area is still the determining factor on velocity (other than the quality of the port shape itself).
Since we have representatives of ET, AFR, Trick Flow (at least a surrogate), Dart, World, and Patriot and numberous porters on this forum, can we start listing the CSAs? I'm sure ET, AFR, TF, TEA, Dart, and World have these numbers for all their heads.
It would be a new and better way...and it could start here!!!
Good idea, but much more difficult to accurately measure. A few of the sponsors you mention can access that info but for the majority of the rest of the heads that info would be unavailable. If the head is a true bolt on design (a ported factory casting or a head that copies that geometry) most of the inlet sizes and shapes are very similar and the valve size is usually known. Whats left in question is the rest of the runner and a simple way of comparing cross section at that point would obviously be volume. But I agree...trying to analyze cross-sectional area when comparing heads with different "architecture" or layout is not as much a slam dunk when comparing runner volumes (but they would still get you in the ballpark if the volumes were sizable differences).
Tony M.
Tony M.
