What size gasket needed to lift compression?
Old 06-21-2006, 11:00 PM
Z28XTC's Avatar
Default What size gasket needed to lift compression?
As the heading says and is it a good mod for some cheap HP if I am getting a tune anyway?And is there any negative points to this?
Old 06-21-2006, 11:56 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
If you are wondering how to raise compression by switching gaskets think again. It wont be enough to matter hardly. You want to have the heads milled for that. And if you were planning on taking the heads off for different gaskets, then you can get them milled instead. Run the MLS gaskets with a 50 thousands mill and you will be needing high octane gas in no time.
