Head and Cam on a budget?
Oh, I have just a lid and a magnaflow catback.
Note, you live in the republic of Kalifornia? Not sure what you can get away with emmissions wise there, wht the smog testing that is done, you may find it alot harder to get to your goals with the testing required.
Then heads, there's quite a few that should work. Patriot, AFR, MTI, etc. Depends on if you want to spend $1400, $2000, or $3000 for the heads. But if you go with a cam, you'll at least have to swap the springs, and new heads usually come with new springs.
Spend the rest on a F.A.S.T./N.W. 90/90 and a really good tune, and maybe some high flow cats, and you should definately be past 400 at the wheels and still pass an inspection.
I would do, ported TB, pulley, headers good ypipe, dual exhaust, 3500 Stall, TR224 cam, and a good tune.
Tom
Tom
2nd I lived in cali, home of the smog ****'s! you will definelty fail with LT headers! won't even pass visual let alone the load test smog machine.
or...find someone that will just pass you, but those days are gettiing harder and harder due to huge fines if they get caught!
so stay with stock manifolds and upgrade everyting around it. sucks because lt's would give you pretty good amount of h.p. with the cam and now is going to be kinda choking it out top end.
and you have to pay the referee also..around 100 bucks if i remember right and if it fails, guess what you got to correct the defects and go back AGAIN to the same referee! so ya you get screwed good!
