Timing sets
Old Jun 23, 2006 | 12:00 PM
12sec_MBM_TA's Avatar
Default Timing sets
What timing set would you recommend with doing a cam swap, a rollmaster or a LS2? If I get a LS2, can I just get the chain or do I have to get the complete set? If I get a rollmaster are they hard to shim? Thanks
Old Jun 23, 2006 | 12:38 PM
One more question, since the car has so much mileage, I should change the valve stem seals, right? What ones do I get and where do I get them at?
Old Jun 23, 2006 | 01:43 PM
02 z/28's Avatar
I did a cam swap and was told the ls2 chain is the way too go.You only need to buy the chain itself,and yes I would chg the valve stem seals.Good luck
Old Jun 23, 2006 | 03:03 PM
Do you happen to know the best place to get the valve seals and the part number?
