Air hose attachment 4 Spring Change???
Pull all the plugs, use thin rope (like clothes line, flexible is better, so don't use stiff plastic type) snaked into a cylinder, bring piston up to the top with a socket on balancer bolt till the rope stops it, change the springs. Quick, cheap, easy, no risk of stripping squat. I also like that it allows you to tap the OD of the retainers with a large diameter socket/hammer to unseat the keepers if they stick to the retainer.
I used the rope method once to change a busted spring on my 71 in the parking lot of the barracks back in my USMC days. The smog heads have huge chambers, had to use a LOT of rope.
