Pro and Cons......Steel block vs Alum.
List em if you got them.
As for weight, it is not a concern for me.
And yes still going to stay with F/I. Thats what started this problem. But cant go back to the N/A side.
1. gets rid of heat better than iron
2. weighs a little less than iron
3. finally with the cost going down of ls1 block compared to lets say 2-3 years ago the only advantage of an iron block is that it is stronger under boost , but then agian you could always throw some darton sleeves in the alum block
Nice thread revival.
). You can find some 408's for nearly the same $ as some 347AL. GL
