Thoughts on this cam?
Old Jun 26, 2006 | 01:09 PM
Skuz1503's Avatar
Default Thoughts on this cam?
Im lookin at gettin this cam. Any thoughts positive or negative on it? https://texas-speed.com/shop/item.as...d=167&catid=44 Also, im debating between gettin the lobe at 112 or at 114, my goal is to still be able to use it as an everyday driver. With this cam i was planning on gettin 918 springs and hardened pushrods... Any thoughts?
Old Jun 26, 2006 | 01:52 PM
CamKing's Avatar
I'd say it's a litle big for an everyday driver with the stock stroke.
The one I'd sell is a custom grind
268°/272° @ .006"
222°/226° @ .050"
143°/147° @ .200"
.340"/.340" Lobe lift
.578"/.578" Valve lift
110°/118° L/C
Old Jun 26, 2006 | 01:56 PM
Studytime's Avatar
268°/272° @ .006"
222°/226° @ .050"
143°/147° @ .200"
110°/118° L/C
A little big? The one you spec'd is bigger (in terms of idle quality). Your grind has more overlap (4 degrees more) than the one he wants on a 114.
Ben T.
Old Jun 26, 2006 | 02:41 PM
Patrick G's Avatar
LS1 Tech Administrator
Ben T.
You may not be looking at his custom cam the right way. In layman's terms, it's:
222/226 114LSA (+4)
-4 degrees of overlap at .050"
The TSP 228/228 cam has +4 degrees of overlap with a 112LSA and 0 degrees of overlap with a 114LSA. Both of these cams would be harder to tune and less desirable for a daily driver (although they're still fairly tame).
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jun 26, 2006 | 02:55 PM
Studytime's Avatar
110°/118° L/C
What's that? I took it as a 110LSA, but what's the 118?
Ben T.
Old Jun 26, 2006 | 03:31 PM
Patrick G's Avatar
Ben T.
110 is the intake centerline. 118 is the exhaust centerline. 114 is the lobe separation angle and the cam is ground with 4 degrees advance (hence the 110ICL).
__________________
Old Jun 26, 2006 | 04:13 PM
CamKing's Avatar
Ben T.
Patrick had it right.
L/C = Lobe Centerline.
When designing a cam, I calculate the Lobe Centerline for the intake and exhaust valves. We grind it at the lobe Seperation it takes to give me those Centerlines.
If the Intake Centerline needs to be a 108, and the exhaust needs to be a 118, we would grind the cam on a 113LSA with 5 degrees advance.(BTW, when you advance the cam, the Intake L/C gets smaller, and the exhaust L/C gets larger)
