Custom Cam Suggestions
Old Jun 26, 2006 | 04:44 PM
ArrestMeRed99Z28's Avatar
Default Custom Cam Suggestions
I know that their are a million different threads that ask the which cam is best for me question, and I've looked at a ton of them. I was thinking about a 228/228 on a 114 LSA, can some cam guru tell me if this will be a good cam for me with long tube headers, stock heads and LS1 intake and 4.10 gears or is it to big? Should I go for a 224/224? I need to drive my car on the street everyday. Would the 228 need a tune just to be able to drive to work? Would a 228/228 on a 116 LSA be a super stealth killer cam? Will XER lobes to hard on Comp Beehive springs? I'll definately be using hardened push rods. Thanks for your time.
AJ
Oh and does anyone know where i can get a custom grind cam cheap? Can I go to comp directly or do they not deal with individuals?
Thanks
Old Jun 26, 2006 | 05:23 PM
eamador11's Avatar
Get my cam..see sig
Old Jun 26, 2006 | 06:08 PM
What kind of tuning did you need? How does it sound? What power numbers, or track times, did you get with this cam?
thanks
Old Jun 26, 2006 | 06:47 PM
dnm12's Avatar
get my cam which i have yet to install you want tq in a cam
On modern day dynamometers horsepower is a calculated value. It's important to remember the dyno measures torque and rpm and then from these calculates horsepower
Old Jun 26, 2006 | 06:55 PM
66deuce's Avatar
AJ
Thanks
TR224 on a 112lsa.that's the best street/strip cam out there for drivability and performance.and yes,you will need a tune to get the most out of it.
Old Jun 26, 2006 | 07:10 PM
dnm12's Avatar
the lift is a little harsh over time on the beehives dual spring could be a good route
this is what i did for the cam:
-224/224 Cam with Lobe Separation Angle=114ş (will pass CA emissions w/cats!!)
-PRC Dual Springs
-Hardened chromoloy pushrods
-Titanium retainers
-Hardened Seats
-LS6 ported oil pump
-Rollmaster single roller non-adjustable timing chain
-Gasket kit
-O-ring for oil pump
-Moore Tool
-Dex-cool raidator fluid
-12 qts. 10w-30 synthetic oil
-2 HP1007 K&N oil filters
-shopvac
-5 gallon bucket/pan
-Tools!!!
-2 5/16" and shave down one side or 1/4" dowels 36" long (cut to size)
-Camera, Food, Drink, time etc...
Old Jun 26, 2006 | 07:26 PM
orangeapeel's Avatar
ЯєŧąяĐ Єlˇmˇиąŧřя ™
224/230 is a great cam. I wouldnt suggest the 244/248 cam for what you are looking for though.
Old Jun 26, 2006 | 07:38 PM
Viper's Avatar
Check your PM's.
Old Jun 27, 2006 | 06:06 AM
Thanks Viper. I decided on a comp XER lobe 224 on a 114. Thanks for all the suggestions.
