Cam regrets..... Post here!
Old Jun 28, 2006 | 08:12 PM
  #41
Kens_02SS's Avatar
226/228 113+1lsa...i'm happy
Old Jun 28, 2006 | 08:32 PM
  #42
redtail2426's Avatar
my car made 396 rwhp with my mods with the stock ws6 catback,stock pulley,and stock paper filter in 92 degrees and 85% humidity,pretty much the worst conditions possible.....Now that i ahve the gmmg and slp pulley on the normal day it should do 420rwhp without a problem.
Old Jun 28, 2006 | 10:18 PM
  #43
2001 White Ws6's Avatar
I wish I would have gone slightly bigger with a traditional split. One of these TSP cams is what I want but won't be getting. 231/237, .598"/.595" - 233/239, .595"/.603"
Old Jun 28, 2006 | 10:30 PM
  #44
DocEwww's Avatar
I wish I went with TTP's V4 instead of the V3
Thats why I'm putting the V3 in the Goat
Old Jun 28, 2006 | 10:37 PM
  #45
keliente's Avatar
Originally Posted by 99whitews6
I hear a lot of, "I should have gone with a larger cam".
Seriously!! I went 230/224. It was tuned in ~5 minutes, way too easy. Would have gone larger if I knew it was going to drive so nice.
Old Jun 28, 2006 | 10:45 PM
  #46
The Dragon's Avatar
Lightbulb
My only regret is they keep coming out with bigger better cams
I SWEAR Texas Speed is out to get my bank account NOW I gotta get the MS4
FYI for you guys: I live in South Florida and regularly deal with 10 mph stop and go traffic on the highways (not so much go but MORE stop). Believe me . . . even if you guys are getting tuned by people that say they "know how to tune" and your cars are STILL having problems with dying/stumbling/erratic idle . . . find a new tuner
My MS3 gives me ZERO problems with a 900 rpm idle. I tune it down to 800 rpm's once in a while when I wanna here a good lope
Old Jun 28, 2006 | 11:31 PM
  #47
SVT THIS's Avatar
DocEwww what did your dyno results look like with the V3?
Old Jun 28, 2006 | 11:46 PM
  #48
SScam68's Avatar
Still haven't put in a cam, but a buddy of mine got a custom grind that helped him trap 111-112 (222/226) here in Albuquerque. Density altitude is REALLY high. FWIW there are guys running MS3 cams only hitting 109 in similar weather.
I was finally able to get the cam card for it and will be installing it once I'm done with the suspension. If I do decide to go bigger I will probably run an X3 or X4 just because they are proven performers.
Old Jun 29, 2006 | 12:49 AM
  #49
DocEwww's Avatar
Made 402rwhp/389rwtq SAE. Car had stock 853s, no EWP or u/d pulley and through a 12 bolt and steel driveshaft. I also think I had a lifter(s) on the way out which is one reason I just pulled my engine after i grenaded my clutch on spray. I'll redyno in the next few weeks with 243s, new lifters, 42lb injectors and the rest of the bolt ons.
The V3 is a pretty high duration cam with even higher lift with a nice lope but drives like stock through TTP's tuning, I love this cam.
Old Jun 29, 2006 | 12:59 AM
  #50
DocEwww's Avatar
Originally Posted by allngn_c5
I can't even get a rematch.
Whys that?
Old Jun 29, 2006 | 07:09 AM
  #51
AU N EGL's Avatar
Originally Posted by you2slo
I also was going to go with the standard TR224 but after reading how people always wanted to go bigger,
I read the same thing. But when I talk to ppl it just the opposit. SHould have gone with better heads and a smaller cam for overall better compatibilty.
PPL like and want to talk about their "BIG numbers", but really want usable power UNDER THE curve.
Old Jun 29, 2006 | 07:17 AM
  #52
ninobrn99's Avatar
My first cam was a f10. 228/228 .558 <<i think)114 put down 378/372 with full boltons with the exception of a pulley. It pulled nicely, but the tune wasnt so great. Not many people had a 228 cam at that time. it was either 224s or 230+ I decided I needed something bigger to keep up with the crowd here in SD so I went with the f13 112. 396/366 is what it put down with mods in sig. this is also through the stock muffler. I miss the low end power from the f10, but im gonna get that back with my new motor more cubes!
Old Jun 29, 2006 | 07:36 AM
  #53
mtb989s's Avatar
Here's another "should have went bigger." I run a 232/240 112 in city traffic with no problems and you can't beat the sound of a larger cam like this. Don't be afraid, you don't give up too much in drivability, it all depends how you will drive it. Although I don't have any problems, if your car is a daily driver and you want to play it safe, stick with a 224-228 range cam because most people have good luck with cam's in this range. Find something you think you might like and stick with it. You will always wish you did or could do something else or go bigger. So it's best to just do some research and buy from someone with good tech support. But remember it's all in the tune and the proper stall match-up.
Good Luck
Any question feel free to pm me
Old Jun 29, 2006 | 06:51 PM
  #54
Phil'sC5vette's Avatar
I had the TR224. Really nice cam, but im having the 228R and AFR install right now......I hope
Old Jun 30, 2006 | 01:02 AM
  #55
highgear's Avatar
Wish I had gotten the Comp LS6 Street Replacement Cam, no tuning required.
Old Jun 30, 2006 | 05:34 AM
  #56
Bo White's Avatar
Cool, get er redynoed with the new exhaust
Old Jun 30, 2006 | 09:38 AM
  #57
00454sscamaro's Avatar
my only regret is not having one yet. or waiting to get one (doing the whole engine at once) to save in the long run. i would like the extra power now..
Old Jun 30, 2006 | 12:33 PM
  #58
NHRATA01's Avatar
Heh, when I got my T1 (.558 221) back in '01, it WAS one of the bigger cams out there. And the car was my DD from April through October and saw 12k miles a year. Now it gets 3k miles per year and sees only good weather. I'm ready to move to something at least 230 and around .600" lift. But I can't complain about the T1, it makes great power, solid torque curve, easy on valve springs, no driveability issues, and even has a nice lope that makes it sound bigger than it really is
That Tony Whatley can pick a good cam
Old Jul 1, 2006 | 07:34 AM
  #59
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Originally Posted by ItsMe
currently fm13 with no problem.
Only regret.. I didnt go bigger
Futral makes some good cams.. and I made decent power with it.
Old Jul 4, 2006 | 08:45 AM
  #60
spun03cobra's Avatar
I currently have a stock motor with a lid, plugs stock exhaust and a slipping A4 running a ls1 hot cam and went 13.02@112 mph with a 2.2 60ft...and the car just has a basline tune, I'm still deciding on what cam to run as of now I'm swithcing to a turbo350 ect.
I like read threads like this as it helps to see what people think of certain camshafts, as for me the hot cam runs great and isnt really noticable unless you listen for it. Bigger is on the way!
