ah!!!!!!oil pressure!
I have a 2000 transam. At a cold start it has around 40lbs of oil pressure and when it comes up to operating temperatures...its around 30. anybody else with this kinda of oil pressure.
Yeah it's common, rule of thumb, 10 psi per 1000 rpm. So technically, you could have 10 psi at idle and be "ok" I wouldn't sweat it. Wait till a cam change and put a ported pump on, problem solved. And if it's an Auto, it may be lower than a 6 speed, just something I noticed between my two cars.
