Need help with cam asap!
Old Jun 29, 2006 | 12:17 PM
Detroitmuscle's Avatar
Default Need help with cam asap!
My TRAK cam from Thunder came in yesterday so I decided to go ahead and do the swap thinking it wouldn't be all the bad the second time around and now I'm having an issue. I pulled the old cam out just fine (LPE GT2-3) and once I try to start the TRAK in it only gets to the second circle (1/4 in from the back) and from there it won't go any further. Initially we had thought maybe a lifter fell but we put the GT2-3 back in just fine. Any ideas I dunno where to start here?
Old Jun 29, 2006 | 12:58 PM
Xtnct00WS6's Avatar
How are you holding the lifters up right now? With a metal rod, I had no trouble.
Old Jun 29, 2006 | 01:01 PM
Gearhead1's Avatar
Could it be that one of the cam bearing journals is slightly oversized?? If you have a mic or a pair of calipers, measure them and see.
Old Jun 29, 2006 | 01:58 PM
The lifters are being held up by the rod and pen magents. As for measuring the cam bearings the Lingenfelter cam is slightly bigger (.01mm) than the TRAK cam. The cam seems to go in just fine but once the second circle gets to the cam hole it goes in just slightly and then feels like its hitting a wall and won't go in any further its weird. Could the cam somehow be out of round?
Old Jun 29, 2006 | 02:34 PM
Gearhead1's Avatar
So the first cam bearing journal goes through without a problem, but the second one hangs up, correct?? If this is the case, check to see if the journal is tapered front to rear.
Old Jun 29, 2006 | 02:57 PM
Yes the second Journal is tapered but I think I have found the problem.
If you look closely you can see that the lobe is bigger than the cam bearing journal. This would cause it to not fit correct? So should I ship it back then? I'll get a good picture of it once the batteries are done charging.
Old Jun 29, 2006 | 03:13 PM
As you can see the first lobe went in due to being able to wiggle the cam but after that its not going to work I'll be calling Thunder asap to find out whats up.
Old Jun 29, 2006 | 03:18 PM
ringram's Avatar
That certainly looks like a jigsaw piece that isnt going anywhere!
Old Jun 29, 2006 | 05:00 PM
Ok called them and the cam is going back.
Old Jun 29, 2006 | 06:37 PM
Bill Bowling's Avatar
Good luck. Hope you get a good one the second time around.
Bill
Old Jun 29, 2006 | 10:53 PM
c0ncEpT's Avatar
MS3? :-D
Old Jun 29, 2006 | 11:03 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Cam looks like it would have sucked if you managed to install it. that was a valve bender for sure right there.
Old Jun 29, 2006 | 11:11 PM
onelife's Avatar
That is so cool though, the lift is so huge that it can't inside the f*&^ing block. I would have never thought I'd say that. Sorry for your misfortune though, hopefully you get it in on the next one.
Old Jun 29, 2006 | 11:45 PM
pla-tym's Avatar
Have Thunder check it before shipping it. I'm sure they will.
Old Jun 29, 2006 | 11:57 PM
ShevrolayZ28's Avatar
Did this come with a cam card?
Old Jun 30, 2006 | 07:52 AM
Yeah it came with a cam card and the lift is massive when it does fit in the block lol.
Old Jun 30, 2006 | 07:56 AM
CBX's Avatar
CBX
That sucks, what a pain in the ***.
