static cranking pressures - opinions please!
Old Jun 30, 2006 | 06:37 PM
jub jub's Avatar
Default static cranking pressures - opinions please!
I'm trying to troubleshoot a miss so I'm starting with the basics.
Plugs look good. Driver's side show just a tad richer than passenger side.
Cranking pressures, engine cold, throttle blade wide open.
1-190 2-210
3-190 4-210
5-190 6-210
7-210 8-210
Mods are in sig. I just recently had the heads off so I could replace lifters and I used stock GM gaskets. I used ARP studs and torqued incrementaly to 65 ft lbs.
I think allowable difference between cylinders is 10%? I'm worried why 1,3, and 5 are lower than the others. I squirted oil in the low cylinders but they didn't come up. Doesn't seem right on an engine with 20k miles.
Any help, ideas or suggestions appreciated.
Old Jun 30, 2006 | 10:21 PM
66deuce's Avatar
if you didn't get an increase in compression by squirting oil in the cylinders,then it's probably your valves not seating properly.i will say your compression test looks a lot better than mine.my lowest was 165 and the highest was 205.the others were 180s and 190s.
Old Jul 1, 2006 | 07:08 AM
jub jub's Avatar
Thanks for your input.
Anyone else?
