Will it run ?????
Old Jul 1, 2006 | 10:22 AM
Sartobuilt's Avatar
Default Will it run ?????
Im having my motor built right now. It should be bone in 2 weeks. This is what I had done... LS6 block Std bore, 3.900 crank (374 ci.) M2 Race LS6 ported heads and a Comp cams XER273 cam, lifters, pushrods and rockers. Compression will bee no more than 10.5:1. (we havent seen where its at yet).
Will my car run ok on the stock computer or do I need to tune right away. Also should I get larger Injectors?
It will have a Supermaxx headers and a LS6 Intake and T body.
Thanks for the help.
How about an air dyno number? Im thinking 450 rwhp?????
Old Jul 1, 2006 | 10:52 AM
PREDATOR-Z's Avatar
You need to tune right away and yes you need injectors. What I would do is get a base tune and break it in on that then do a dyno tune.
28.8 injectors are maxed at those HP levels during WOT.
Old Jul 1, 2006 | 11:12 AM
Sartobuilt's Avatar
Whats the best way to get a base tune?
There is a local guy that tunes. Will he be able to do a safe base tune?
Or should I purchase a handheld tuner?
Old Jul 1, 2006 | 11:56 AM
PREDATOR-Z's Avatar
I would contact LS1 Speed (Speed inc) in Chicago area. You can work a deal with them on a mail tune, followed by dyno tune later. They have 30lbs SVO injectors too if you do not plan on nitrous, otherwise get 42lbs.
Old Jul 3, 2006 | 09:05 AM
Sartobuilt's Avatar
bumps
