What cam are you running with your AFR 205's???
I've tried a few setups like AFR's 224,GX3 and a bunch of other Cams. I prefer a 230/228 .595/.595 on a 112. It gave the best midrange/average power with awesome drivability.
Do you want a high dyno -peak- # or a good average power (across the rev range)?
well i called TSP and they said my .030 milled 205 AFRs should work with the 233-239 cam i have. im using stock gaskets since i work at a gm dealership.
i will be installin it asap no more than a month from now. i guess i will let ya know on the P/V clearance cause im sure as he** gonna check.
