Anyone heard of this cam?
Old Jul 3, 2006 | 08:01 PM
VenomInside's Avatar
Default Anyone heard of this cam?
A Cammotion F113 cam.
Anyone heard of it? Good, bad. Anyone got the duration and lift specs?
Old Jul 3, 2006 | 08:11 PM
00transamnh's Avatar
um... are you refuring to futrals f13 cam?
Old Jul 3, 2006 | 08:12 PM
PSJ's Avatar
PSJ
Here is their site....Call and ask them about it.
http://www.cammotion.com/DesktopDefault.aspx?tabid=56
You can also download their catalog. ( maybe it is in there ).
PSJ
Old Jul 3, 2006 | 08:24 PM
dammit, that cam is not on their site.
Old Jul 4, 2006 | 04:09 AM
PREDATOR-Z's Avatar
FM1-F13-112 FMS Custom Grind Camshaft - 230"/232" .595"/.585" 112LSA - aggressive profile with a 2500-6800 RPM range, rough idle $399.00
FM1-F13-114 FMS Custom Grind Camshaft - 230"/232" .595"/.585" 114LSA - aggressive profile with a 2500-6800 RPM range, rough idle
http://www.futralmotorsports.com/fms....asp?pf=1&pg=5
Old Jul 4, 2006 | 08:32 AM
ss2000's Avatar
maybe it's one of these new fms cams.
FM-F13-112-HIGHLIFT
New Item! FMS Custom Grind Camshaft - 230"/232" .642"/.612" 112LSA - aggressive profile with a 2500-6800 RPM range, rough idle $399.00
FM-F13-114-HIGHLIFT
New Item! FMS Custom Grind Camshaft - 230"/232" .642"/.612" 114LSA - aggressive profile with a 2500-6800 RPM range, rough idle $399.00
FM-F14-112-HIGHLIFT
New Item! FMS Custom Grind Camshaft - 232"/234" .646"/.612" 112LSA - aggressive profile with a 3000-7000 RPM range, rough idle $399.00
FM-F14-114-HIGHLIFT
New Item! FMS Custom Grind Camshaft - 232"/234" .646"/.612" 114LSA - aggressive profile with a 3000-7000 RPM range, rough idle $399.00
Old Jul 4, 2006 | 02:36 PM
Gracias guys.. you rock!
Old Jul 4, 2006 | 07:22 PM
GuitsBoy's Avatar
FM-F13-112-HIGHLIFT
FM-F13-114-HIGHLIFT
FM-F14-112-HIGHLIFT
FM-F14-114-HIGHLIFT
WOW, those look beefy!
Old Jul 4, 2006 | 07:28 PM
cws T/A's Avatar
new highlift FMS cams
would this work in stock ls1
Old Jul 4, 2006 | 10:04 PM
I am most likely getting the F113. So i'll let you know.
