This chirp is driving me INSANE!!!!
Old Jul 10, 2006 | 12:25 PM
Grillrd's Avatar
I had same problem...fixed it today...I had one header bolt come loose...was a header leak on the passenger side...
Old Jul 11, 2006 | 08:53 PM
juiSSed1172's Avatar
Second update..
My AC isn't working now.. So, maybe this time it WAS the AC compressor.
Damnit. Blows hot air... and when I flip the AC on the motor doesn't load up like normal....
Awesome. I'll have to check in the morning to verify if the belt is even there.
I guess that's better than a lifter... maybe not cheaper.. but it's not critical to my commute and a lot easier to fix. Damnit.
Old Sep 10, 2014 | 07:37 PM
Michael Levitz's Avatar
I have a 2000 T/A WS6 with A4 trans. I am experiencing the chirp noise. It sounds like its coming from the passenger side valve cover on the motor. I had a shop pop the valve cover off. they replaced some push rods and lifters that went bad but that did not do it. So if you found a fix. I know this thread was started a while ago. But can you post here or PM what took care of it? Other than selling your car OR rebuilding the block (if block was rebuild did they find what most likely could have been causing it?) Thanks!
Old Sep 11, 2014 | 07:42 PM
S10xGN's Avatar
From the OP's public profile:
  • Last Activity: 04-10-2012 05:10 PM
Old Sep 11, 2014 | 10:27 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Yeah, this is a dead thread.
Michael, re-post your thing in the Firebird section. We'll get that chirping bird quieted down.
Old Sep 12, 2014 | 08:56 PM
thedetroitkid's Avatar
I'm going on bet all my marbles that it's your ac compressor. I had the same issue.
