Too much DCR?
Old Jul 7, 2006 | 11:50 PM
Patrick G's Avatar
LS1 Tech Administrator
Originally Posted by Beast96Z
Which is still a guesstimation, correct?
You know it!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jul 10, 2006 | 12:10 PM
exSSer's Avatar
Originally Posted by Patrick G
That gets me back to my original post of 278/282.
Turns out you're pretty close, Patrick. I phoned Crane, and got this further info.
ADV duration @ .006 is 281* intake, and 285* ex. So plugging in the other parameters for a stock bottom end LS6 with 61cc heads, I get an SCR of 11.17, and a DCR of 8.31 which should be OK with 92 octane, n'es pas?
Old Jul 10, 2006 | 01:13 PM
PREDATOR-Z's Avatar
Oui, oui C'est bon comme cela.
Old Jul 10, 2006 | 01:25 PM
ringram's Avatar
Zut alors
Old Jul 10, 2006 | 04:54 PM
exSSer's Avatar
Oh great! This calculating business sure is fun. I've found even more bad data that skews the final #s. Crane now tells me there's 5* advance ground in, which would move my ICL to 107*. Also, I was figuring a MLS (stock GM) at .052 compressed, and should be .060. So anyway, the new #s make the final (Keerist, I hope) SCR @ 10.94, and the DCR @ 8.5. Still OK for pump gas, methinks.
Hope this combo runs good, Crane sure doesn't tell you all the particulars upfront.
Old Jul 11, 2006 | 06:27 AM
No Juice's Avatar
I thought the Stock GM or MLS gasket was 0.053 compressed??? Are you sure its 0.060??
Old Jul 11, 2006 | 08:10 AM
Viper's Avatar
I thought it was .052 compressed, that's the figures I've been using in calcs.
Old Jul 11, 2006 | 10:52 AM
MNR-0's Avatar
I run essentially the same combo you are building. 11.4:1SCR, 10.5:1 idle CR and 9.5:1 DCR running. 57cc chambers, 2.5cc valve reliefs. Crane 228-232-112+5. Install the cam retarded 2* though. Mines installed straight up and for track work 2* retarded has shown to hold 400rwhp+ from 6000-7000RPM, very broad. This combo makes over 300rwkw here in OZ, or 400rwhp through a 4000 stalled A4. Bolt that through an M6 and expect 440rwhp or more. My idle vacuum is 55kPa, very idle friendly at 860RPM and a killer idle.
Best times similar combo over here 11.4@120MPH heavy *** commodore full weight 3600lbs. Are we feeling better?
Old Jul 11, 2006 | 11:20 AM
exSSer's Avatar
I've gone through lots of old posts doing searches, and that's the figure that keeps coming up. At .052 my #s translate to 11.17, and 8.69 DCR.
edit: I checked the calculator. The stock '02+ MLS gaskets ARE .060 compressed, because using this figure, my stock CR computes to 10.48:1, which is correct.
Thanks to our down under brother. I'd planned on installing the cam dot to dot, and haven't a clue how to degree the thing. Hope that I get lucky, I guess. It'll run through a 6 speed, and also will be equipped with a ported FAST/LS2 90, and since the car only weighs about 3100, should be plenty fast.
