PLUG Gap ?
Old Jul 8, 2006 | 01:35 AM
edlt1's Avatar
Default PLUG Gap ?
On my buddy's 98 ls1 what should he gap the plugs too?
He has a hotcam,full exhaust and just did a tune up.
Thanks
Ed
Old Jul 8, 2006 | 03:18 AM
PREDATOR-Z's Avatar
Old Jul 8, 2006 | 07:34 AM
ringram's Avatar
Yep bigger is better... as long as it works.
Old Jul 8, 2006 | 02:34 PM
BriancWS6's Avatar
I'm assuming this is on a set of TR55s? If so, .050-.055.
Old Jul 8, 2006 | 07:27 PM
edlt1's Avatar
so bigger gap is better?
I have mine gapped at 38 right now for a 150 shot of nitrous.
Would it be better for me to just use plugs gap to 38 when I am using the nitrous. Then just use 50 when I am driving around.
Old Jul 8, 2006 | 08:27 PM
BriancWS6's Avatar
NO, if your running TR6s just leave them alone at .038. I drive mine 99.9% of the time without running the juice and I am using TR6s gapped @ .038.
The plugs that we're talking about in this thread however are the TR55s (not for N2O use) so if your spraying on TR55s then you need to get them outta there asap.
Old Aug 12, 2006 | 11:19 AM
edlt1's Avatar
These plugs in this formula my friend has with the hotcam were gapped to .026 when he first got it. they are gapped at .060 right now and the car got a lot slower.
Old Aug 12, 2006 | 11:28 AM
PREDATOR-Z's Avatar
.060 is too big
.050
He is prolly experiencing missfire
Old Aug 12, 2006 | 04:44 PM
edlt1's Avatar
umm no, its just not that powerful.
I am missfiring though. I have an lt-1 gapped to .038 for a 100shot of nitrous.
I wonder if I shoudl gap them larger
Old Aug 13, 2006 | 07:15 AM
PREDATOR-Z's Avatar
I do not think you are understanding.
For nitrous you use at least 1 range colder plug for up to 150 shot.
It is gapped tighter because under nitrous, the cylinder pressures are so high that it could blow the spark if gap is too large. Tight gaps reduce that effect.
NA, too large a gap can induce missfire for the same reasons under high rpm.
Old Aug 13, 2006 | 10:32 AM
SSDoubleK's Avatar
.052 to .056 will be just fine.
Old Nov 14, 2006 | 09:45 AM
TheLS1Kid's Avatar
sorry to bring this old post up again but i just got some tr6's and im not quite sure what to gap them to. Im not sure if how much power it makes matters but just incase they are going on a 468rwhp N/A LS1. im guessing somewhere around .40 to .50 but i just want to make sure. thanks guys
Old Nov 14, 2006 | 10:28 AM
PREDATOR-Z's Avatar
IIRC they come gapped at .035
Just check gap and leave them at that.
Old Nov 14, 2006 | 10:45 AM
TheLS1Kid's Avatar
does it matter if it is a 11.5:1 compression motor?
Old Nov 14, 2006 | 10:50 AM
PREDATOR-Z's Avatar
then .035 would be perfect
Old Nov 14, 2006 | 10:54 AM
TheLS1Kid's Avatar
thanks a ton man. i really appreciate it
Old Nov 28, 2006 | 11:42 AM
Fedge's Avatar
Originally Posted by PREDATOR-Z
.060 is too big
.050
do you mean too big for aftermarket?
it says .060 on the info sticker under the hood.
I'm disturbed to find out that my Delco Iridiums are supposed to be gapped at .040, but on the package it says to gap to factory specs.
well, I guess I'll hafta spend another 60 bux, cuz I put around 5k on these plugs in a new engine and I don't wanna do the job twice.
Old Nov 28, 2006 | 11:45 AM
Fedge's Avatar
so with a .020 'overgap', how much power am I losing? I mean are we talking 5-10 or 20-30? I've never had plugs that were gapped wrong (always used stock plugs and factory gaps), but I did notice the car was a little sluggish, all this time, I thought i just had high expectations, lol
Old Nov 28, 2006 | 12:21 PM
GuitsBoy's Avatar
I use tr6's gapped at .045 with 11:1 CR N/A
