Trick Flow heads in the 10s!
Old Jul 9, 2006 | 06:04 PM
1FSTBRD's Avatar
MAN THOSE ARE AWSOME #'S CAN I REPLICATE YOUR SETUP PLEASE LET ME KNOW AND IF YES THANK YOU
Old Jul 9, 2006 | 06:58 PM
Black02SS's Avatar
Great times John!!! Very impressive. Keep it up. Makes me want to get a A4 just so I can hit 10's too. My 1.7 60's just don't cut it with a 3650 raceweight.
Old Jul 9, 2006 | 07:23 PM
TJ's Avatar
TJ
is it time for a cam swap?
hehe.
Old Jul 9, 2006 | 07:27 PM
slimcracka's Avatar
hehe.
dork
Old Jul 9, 2006 | 07:28 PM
JNorris's Avatar
Moderator
Sure copy away.....See ingredients below!
Stock short block
Total Engine Airflow (TEA) Trick Flow LSx heads
.053 GM graphite head gaskets
Quench - .046
Static compression – 11.1:1
Dynamic compression – 8.5:1
Cam is a LG grind 230/230 .595/.595
Stock rockers and lifters
Edelbrock long tube headers
Edelbrock off road Y-pipe
Stock 2-3/4 I-pipe
Single in/out Dynomax muffler exiting in the stock location
ASP under drive pulley
LS6 valley cover and PCV system with an AMW catch can
FAST 90mm intake
Nick Williams 90mm TB
Stock screened MAF
Stock water pump
Stock coil packs
Fast Toys ram air kit
MTI lid with a K&N air filter
TCI 4000 torque converter
3.73 gears with an Auburn Pro carrier in the stock 10 bolt rear and axels
BMR sub frame connectors, k-member, LCA, and LCA relocation brackets
Hal R front shocks and springs, Hal F rear shocks and stock springs
Airbag in the right rear spring
Spohn 1” rear sway bar
Spohn adjustable torque arm with built in driveshaft loop
Stock brakes
Car is tuned by me using EFI Live
I am a conservative tuner, I run ~12.2-12.5 AFR and less than stock timing. All shifts are completed by 6450 RPM.
All installation work is completed by me.
Old Jul 9, 2006 | 07:29 PM
JNorris's Avatar
Moderator
hehe.
Sure! Any suggestions?
John
Old Jul 9, 2006 | 07:32 PM
JNorris's Avatar
Moderator
Originally Posted by Bill Bowling
I am looking at heads. What vendor do you get them from? What springs/values do they run?
Great numbers.
Bill
I got the heads from Total Engine Airflow (TEA). Talk with Brian Tooley or Mike.
The springs are dual springs with Ti retainers; the valves are 2.04 on the intake and 1.575 on the exhaust.
John
Old Jul 9, 2006 | 07:46 PM
AINT SKEERED's Avatar
Damn John, glad to hear the heads are doing a good job of making hp. Congrats!
Old Jul 9, 2006 | 10:27 PM
1FSTBRD's Avatar
Thanks Alot You Are The Man When I Can Afford To Do It I Wont Forget Who Got Me There Thanks
Old Jul 9, 2006 | 10:51 PM
TJ's Avatar
TJ
John
some
thing
B
I
G
Old Jul 10, 2006 | 01:01 AM
stripes1987's Avatar
Thanks guys.
Predator-Z – To measure DA I go to www.weatherunderground and get the conditions at the time of my run and then go to http://wahiduddin.net/calc/calc_da.htm and plug in the numbers.
You can buy a device such as http://store.summitracing.com/partde...5&autoview=sku that will do it for you at the track.
I do not know how much RWHP the setup is putting down. I do know that with my old setup I would run even with a buddy of mine that had almost the exact setup and put down ~425 RWHP through a locked 4L60E.
With the above as a ruler I would guess that the current setup is putting down some where between 425 and 450 RWHP with the converter locked
Louis – I have not heard or seen you post in a long time. How are you? Also thanks for a great cam!
Hennytime – You are right. I should have said “a baby cam by today’s standards”
exSSer – My heads are out of the box Trick Flow heads milled to 61cc chambers. You are going to love the heads!
John
hey we re-dynod the car again with the rings seated a little more and it did 438/393 through a locked 4000stall converter 20lb driveshaft and a 12 bolt so your car im sure is deffinatly making good power. i have to say the one thing you have over me by far is the damn weight of the car mine weighs 3460 without driver so its kinda heavy
im hoping to pull off 11.1-11.2 or a 7.1-7.2 in the 1/8 we went to the track the other night and the car went 7.36 but it woulnt shift into third it kept banging the limiter, but we got that fixed now and the tires where rubbing at the track so i have to roll the fenders this week before i go back, that will kill the mph and than we will see what she does
-david
Old Jul 10, 2006 | 01:38 AM
  #32
Boostaholic's Avatar
Well done, now add some spray
when I started my car the initial goal was to run 10s too
Old Jul 10, 2006 | 02:30 AM
  #33
i have the trick flow heads for anyone that doesnt know and it did 410rwhp unlocked and i sprayed mine and on a 200shot it did 565 unlocked and 470torque spinning bfg drag radial 315's on the dyno. the converter flashed to 6k on the dyno and the pull only lasted 1.5 seconds the reason it seems the torque is down alot and a little power is because it flashed to 6k and it already flahsed above the peak numbers but on the street it should fall right around 5300 and do more than that so im happy with it
Old Jul 10, 2006 | 09:12 AM
  #34
Brian Tooley Racing's Avatar
some
thing
B
I
G
A Comp shelf 216/220 cam with these heads made 515 HP at the crank, a 232/236 made 535 HP, so if there is a 20 HP spread from tiny cam to big cam, how much more power is he going to make? and is the gain in peak power going to cost area under the curve?......yes.
I can't count how many customers I have had that had a good, drivable, killer combinations and then killed it with a huge cam.
Congrats on the killer numbers John, I knew if anyone could do it you could.
Old Jul 10, 2006 | 09:46 AM
  #35
DavidNJ's Avatar
Brian,
what was the compression ratio, quench height, and fuel in your test?
Thanks,
David
Old Jul 10, 2006 | 10:15 AM
  #36
Photochop's Avatar
Wow, very impressive ET/MPH
Is your FAST 90 intake portmatched to your heads?
Old Jul 10, 2006 | 03:40 PM
  #37
Blue Meanie's Avatar
Damn this post gave me a joygasm. My 61cc milled TEA trick Flows arrive later this week I hope, slightly bigger cam. I am so damn excited its rediculous.
Old Jul 10, 2006 | 03:45 PM
  #38
Originally Posted by DavidNJ
Brian,
Thanks,
David
The head was at 64cc, the head gasket was stock MLS and the fuel was pump 92. So you can figure compression from that and the quench was probably .046" (.054"-.008") Not near as high of compression as a lot of people are trying to run, with 59cc chamber and .040" Cometic gasket, but then again I bet John Norris's rod bearings stay in the engine that way
Old Jul 10, 2006 | 03:52 PM
  #39
You should go back and look at the MPH on each run and see if you were blowing through the convertor, it sounds like you were, and even if you weren't, 6000 flash is no good. Is it a purple puck by chance?
In my car I blew through the Super Yank 24 MPH, so you need a very good torque convertor.
Old Jul 10, 2006 | 04:24 PM
  #40
dug's Avatar
dug
Originally Posted by Hennytime
i wouldnt call a 230/230 a baby cam, and DAMN THATS FAST, nice job
Mine is similar and its mellow. Drives good on a stock tune and gets the same mileage as stock. It is a lil soggy below 2500rpms though.
