Help with Cometic HG and 853 head
Old Jul 10, 2006 | 03:36 PM
Tri5Nerd's Avatar
Default Help with Cometic HG and 853 head
I have some 853 heads and cometic .040" gasket, when I tried to match the gasket to the head it appears that there is some holes that is covered by the gasket, are these not correct for these heads?
Look at the attached pic.
Old Jul 10, 2006 | 03:39 PM
GuitsBoy's Avatar
Do the 853 heads have the notch that makes these gaskets leak? Maybe it was just the 806 castings.
Old Jul 10, 2006 | 03:41 PM
Tri5Nerd's Avatar
These do have the notch on, will these cause them to leak?
Old Jul 10, 2006 | 03:44 PM
GuitsBoy's Avatar
I think it may. match up the ribbing in the head gasket to see if it compartmentalizes out the notch. If not, then leak. Check out some mr. gasket .042's. theyre cheap and i believe theyre compatible with teh notched heads or otherwise.
Old Jul 10, 2006 | 03:57 PM
NaSSty Nate's Avatar
I'm having a problem sealing the same exact gasket right now...853 head with .040 cometic....
Old Jul 10, 2006 | 03:59 PM
GuitsBoy's Avatar
Glad you found this, i was just gonna point you to this thread...
Old Jul 10, 2006 | 04:03 PM
Tri5Nerd's Avatar
Default Missing holes in the gasket
If you look at the pic you'll see that the yellow circles (left side) does not have provisions for the holes in the head compared to the red circles (right side), will this also be a issue?
Old Jul 10, 2006 | 04:06 PM
I even sprayed copper gasket sealer on it and still blowing white smoke through the exhaust. Small chance of it just being the gasket sealer burning off that may have got onto the edges and into the cylinder/combustion chamber. Just drove it last night for about 20 mins will see again later today.
Old Jul 10, 2006 | 04:08 PM
GuitsBoy's Avatar
well, if its not sealing because of the head recess, it would just leak out teh side of the block from under the head.
Old Jul 10, 2006 | 04:12 PM
So what would you suggest from this point? pull the head and put a graphite gasket (stock GM one) or try the coolant stop leak?
Old Jul 10, 2006 | 04:22 PM
GuitsBoy's Avatar
Forget the stop leak. Looks liek youre gonna have to pull the head and see whats going on. Stop leak, even if it did work, dosnt treat the cause.
Old Jul 10, 2006 | 04:57 PM
Beast96Z's Avatar
There are still holes in the area's you circled, there just smaller. Just like the holes in the middle. If you look at the block, the holes are long and narrow, but the gasket only has one small hole. I believe the small holes are supposed to go in the back if I'm not mistaken. You can also drill you another hole if your not comfortable with the small one in the gasket.
Old Jul 10, 2006 | 05:05 PM
ArcticZ28's Avatar
Wouldn't flipping that gasket horizontally fix the problem? You've got holes in the gasket where there are no holes in the head, and you've got no holes in the gasket where you have holes in the head. Is there something I'm missing here, I'm just trying to go by the pic here...
Old Jul 10, 2006 | 05:11 PM
Tri5Nerd's Avatar
No, both sides of the head has the same set of holes/passage way, and those holes are only on one side of the gasket. Shouldn't they be on both sides?
Edit; I just looked at a MLS Graphite gasket and it has holes in both sides not like the Cometic.
Old Jul 10, 2006 | 05:15 PM
ArcticZ28's Avatar
It doesn't look like there are holes on the right side of the head, of course I can't really see much from the small picture. They are obviously the wrong gaskets if the holes don't match up, who sold those to you and said they would work?
Old Jul 10, 2006 | 05:18 PM
Tri5Nerd's Avatar
A sponsor, I'll contact them and talk to them about this. I'm not happy.
Old Jul 10, 2006 | 06:03 PM
LS1-450's Avatar
I just looked @ my used GM stock graphite gaskets pulled from a 99. The gaskets have large holes @ one end & small holes @ the other. The large holes go over the rear & the small holes @ the front. I think GM does this to ensure fluid is flowing through the back of the block/heads. If the small holes were in the back, the coolant may find an easier path through the front of the head/block & limit rear circulation. On the stock gaskets, the front of the gasket is labled. The small holes are on the front side of the gaskets.
The Cometics that were installed in their place also had the small holes @ the front & large holes in the rear (back of the block/heads).
As to the notch/no notch, I haven't a clue other than to say that the Lingenfelter web site states that #853 @ #904 for 98, 99 & some 2000 heads have the notch & require the gasket specific to the notched heads.
Old Jul 10, 2006 | 06:15 PM
Tri5Nerd's Avatar
Default Got an answer!
Just talked to the shop and they said that the holes in the gasket should line up with the holes in the back of the block which makes sense now, I was just confused because the head has the holes at both the front and back.
As for the leaking with the notch, they told me to get some Permatex copper spray and spray 2 liberal coats on both sides waiting a few minutes between coats then waiting 5 minutes before putting and bolting the heads on.
Hope this helps and works.
