Head Machining For Solid Roller Springs?
Old Jul 12, 2006 | 09:36 AM
98 Silver Bullet's Avatar
Default Head Machining For Solid Roller Springs?
What machine work (if any) other than cutting larger valve pockets has to be done to install springs for a solid roller setup?
Old Jul 12, 2006 | 10:06 AM
Classic's Avatar
Depending on the rockers used, you may or may not have to clearance the valve cover rail for the tail of the rocker. You also will likely need to open up the pushrod area so the pushrod will not hit and also for more room to run a larger diameter pushrod.
