installing harland rocker arms
I've had the Harlans on my car so I'm talking from experience. Don't get them. I bought them before I planned to get a cam and it severly limited my cam choices after that. The rockers are very heavy over the nose so it is more risky at high rpm. (the valve springs have to work harder to compensate for the weight.) When I took them off one of the roller bearings was going to self-destruct probably within 10k more miles. Fluke defect?
If you decide to get rockers get 1.7's so you can use them with any cam out there. Harlans are good on the Gen I engines but are straight junk (I don't know why) on the Gen III motors. You get what you pay for usually and there's a reason they are the cheapest rockers by far on the market.
If you want to get the extra lift just get a cam and you'll never miss the .30 lift the 1.8's gave you while limiting future choices. On average the 1.8's will dyno just 7 rwhp if that on a stock cam. Not worth the effort considering you have to buy new valve springs anyway to install them, just do the cam/springs. ~Joshua
