Heads&Cam or Force Induction
Old Jul 20, 2006 | 02:24 AM
00454sscamaro's Avatar
ms4- i think it depends on the lsa. if you buy there heads they had in that dyno section, then you need flycutting because of bigger valves..... what i read.
Old Jul 20, 2006 | 03:10 AM
300bhp/ton's Avatar
Originally Posted by ninetres
TSP told my buddy (crazy camaro) the MS4 requires flycutting
Maybe my bad then.
But in an other wise stock engine the MS4 should be fine, it's not as big as a Trek and that fits without flycutting. But I will admit some aftermarket heads will require flycutting. Do you know what heads you friend has?
Old Jul 20, 2006 | 05:58 AM
magius231's Avatar
Originally Posted by viewsonic
Not true.... I am making more power than most guys under boost...
I made 513rwhp and 457 rwtq with my H/C setup.
H/C with every bolt-on is about the same cost as a procharger.
I love my ungodly sounding H/C setup.... Sounds like good ol' fashioned American Muscle!
Mind sharing your setup?
Old Jul 20, 2006 | 08:11 AM
viewsonic's Avatar
linky :
https://ls1tech.com/forums/generation-iii-internal-engine/541723-h-c-install-almost-done.html
Old Jul 21, 2006 | 08:25 PM
magius231's Avatar
nice, thanks!
