ARP head bolts or head studs???
Old Jul 18, 2006 | 06:16 PM
Phil99vette's Avatar
7 Second Club
I can't say for sure but we have had 2 cars with ARP bolts and Cometic Gaskets leak. The rest of the cars we have done were with ARP studs and no leakage. Not sure if there is a correlation but we will not use bolts anymore.
Phil
Old Jul 18, 2006 | 06:40 PM
viewsonic's Avatar
Phil
Bolts/Studs perform the same.
Should not make a difference...
However if you are taking heads on and off studs are reccomended so you don't have to clean the bolt holes everytime
Who ever asked about tqing procedure.... ARP does not provide a tqing procedure....
However follow these rules with arp bolts:
With Arp Lube
Torque all 15mm bolts to 30lbft in the torque sequence above. Do a second pass at 50lbft, and finally a 3rd at 70lbft.
Finally install the 5 smaller ARP bolts and torque them to 22lbft.
With motor oil:
Torque all 15mm bolts to 35lbft in the torque sequence above. Do a second pass at 60lbft, and finally a 3rd at 85lbft.
Finally install the 5 smaller ARP bolts and torque them to 28lbft.
Old Jul 18, 2006 | 07:49 PM
2002/Black/SS's Avatar
thankx ill save this thread
