Checking rocker bolts after H/C swap
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Just finished a H/C swap back in march and i have put under 1000 miles on the car since. No problems at all, everything went great.
My question is, since i am doing some work and have the coil packs off, does it pay for me to check/re-torque the rocker arm bolts?
Anyone see a need for this or done this before?
Thanks
Thanks
you could, but if its working great is there a need to do that?
THey shouldnt loosen once properly set.
Its up to you, will u have to reseal the threads?
personally i wouldnt touch them if there were no symptoms.
