98 timing chain issue!!
Old Jul 24, 2006 | 08:48 PM
curtisad's Avatar
Default 98 timing chain issue!!
I noticed that my stock timing chain is not lining up perfectly. Does this happen from the factory or has my chain jumped a tooth? The chain does seem to be a litt;e ;oose. Anyone have any insight with this?
Curtis
Old Jul 25, 2006 | 08:22 AM
Z'mnypit's Avatar
I doubt that its jumped a tooth. Its possible that its stretched that far even though it may not fill like it has. I seen one once that a guy drove through some water and almost hydrolocked the motor, it put enough stress on the motor it stretched the timing chain out causing it to be off a tooth. While you got it apart you might as well swap it out for the LS2 timing chain.
Old Jul 25, 2006 | 09:44 AM
Slo_240sx's Avatar
Upgrade to the LS2 chain and call it a day. New gears would be highly reccomended also.
