Oil Plumes under accel, using lots of oil.
WEll here is the deal, the car was using oil when i bought it. So i took the valve covers off and found no sealant on the rocker threads so i put some on and put it back together. Now its way worse, using more oil and puffs really bad sometimes at startup.
I was going to do the seals but saw the first 2 and saw they were holding oil and looked fine.
ANy advice?
Its sputtering from a driver side coil failure but when its running good it still puffs.
I dont know how it could get worse now...being i put sealant on unless seals magically gave out at this time.
HELP!
ANy advice?
HELP!
