What the hell happened on the way home?
Old Aug 1, 2006 | 02:07 AM
ArcticZ28's Avatar
injector cleaner goes in tomorrow and I guess I will be replacing the filter at some point in the next week while the cleaner takes its course.
Old Aug 1, 2006 | 04:08 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
That will be an easy problem eliminator if it fixes the issue. All that damn ethanol in the gas these days is mutilating our fuel filters and entire fuel systems for that matter.
Old Aug 1, 2006 | 11:34 AM
67Firebird455's Avatar
I hope you get it fixed bud, I feel your pain.
Old Aug 1, 2006 | 01:44 PM
Z'mnypit's Avatar
Originally Posted by OUTLAWZ RACING
Oh and as far as the water temp sensor it set no ses code and the gauge read 180-210 go figure and I have an 02. But when I logged it when it hit -60 the car would bogg and then it will shoot to 210 and she would pull. Huh go figure
You know Im glad I read this. I have the same damn issue, the car will run fine then all of a sudden it will bog like its flooding out then eventually die. Sometimes I can keep it alive and it will take back off like nothing was ever wrong. Everytime I log with HPtuners I can ever get it to do that. Now I have something to look for. It mainly happens after I drive it for about 10mins or so then starting sitting with it idling. So what did you have to do to correct this?
Old Aug 2, 2006 | 11:00 AM
muncie21's Avatar
I had a similar issue that turned out to be a loose wire on the coolant temp sensor. The temps would swing from -xx (causing bog) to 280+. Replaced the sensor (broken plastic connector) and everything ran fine.
