Comp R lifters......
Old Jul 27, 2006 | 11:18 PM
moeZ28's Avatar
Default Comp R lifters......
Can these be used with stock rockers, or do you have to have adjustable rockers for those lifters. I had comp oem replacement lifters in my motor and i guess they werent good enough. i am turning my motor over 7k, and want a lifter that i can count on, but i dont want to spend $400 bucks when i could spend around $200 for these. i know you get what you pay for, but i cant pull that at this moment. been a little short since i built the damn motor in the first place.
Old Jul 28, 2006 | 05:19 AM
Slowhawk's Avatar
LS1Tech Sponsor
Yes you can run stock rocker's.Just need to adjust pushrod length for the correct preload on the lifter. I found .004 to .006 preload makes them quiet.
Old Jul 28, 2006 | 12:28 PM
dummer's Avatar
Just wondering, could I ask, what you meant when you said the eom replacement comp's weren't good enough? Did they bust up or what?
Old Jul 28, 2006 | 01:58 PM
mike c.'s Avatar
the comp 850-16 will work fine. alot of people run them w/no problems.
Old Jul 28, 2006 | 11:53 PM
moeZ28's Avatar
I am pulling the heads tomorrow, and i am pretty sure i busted them. my rev limiter is at 7200 rpms and i think i may be pushing them too hard.
