built motor guys inside please
For what it's worth, I'm building a larger CI motor that will see nitrous, and will be spun over 7000 most likly.. so what you have to say is revelant.
JL...20-50 is not straight weight, straight weight is SAE 40, (no 10-, or 0- etc).
Also, personally I think your doing more harm than good changing oil with so little time on it. Petroleum products are designed to operate in certain environments, and changing oil every 500 miles is something I would do with the cheapest $.78/qt STRAIGHT 30w or something for break-in. I have been running loads of nitrous in this built engine and the stocker. When I tore my stocker down it looked almost new inside, that was with 50,000+ miles and more than a fair share of nitrous thru it, I used M 10-40 or 0-40, depending on availability.
In my new engine, which is built for 300shots, and I do spin it up and over the 7k mark, I broke it in with the cheapest non-syn oil, and then switched to M1 again. I spoke with Patman, and find it beneficial to run the Redline, or Amsoil synthetic 10-40. Yes my bearings are set for nitrous, and I gapped the rings for nitrous as well. Yes I go thru almost 1qt/1500miles or so, but still, thats due to the rings etc, which you should be told about during your build...a looser engine will consume oil.
Its your engine, your builders recommendation etc.. just talk to him about it.
Charlie
I'm no oil expert and maybe there are dino oils that offer good protection for high-performance, high-rpm applications, but to me synthetics are proven in this regard and give me added insurance when spinning my motor to the moon.
BTW - The imaginary scenario depicted above happened to my friend with a 89 Mustang GT while at the track. We were convinced the motor would have seized up had he been running conventional oil at the time.
I find it almost impossible for any damage to occur by changing the oil too often other then putting wear on the drain plug bolts. All that is gonna happen is the life blood fo the engine is gonna be cleaner.
I'll be going with my builders reccomendation, regardless what I find on here, I almost wish I hadn't even asked at this point.
I will have an oil analysis done after the initial break in is done, and will keep an eye on it.
Thank you for the feedback everyone.
LME told me to run regular dino oil (castrol 10w40 is in mine) and not worry about break ins because the motor was ready to go as soon as i was willing to go WOT. I'm wanting to switch to a 10w30 or 40 synthetic to pick up more power and better protection.
Now,synthetic is worth it even if you change your oil every 500 miles due to the heat it can take.
PurEvl car runs 800rwhp all the time,probly 5-6k miles this year with a Turbo and runs 0w/40(synthetic) with oil pressure at 40-50psi at idle.This is more strain on bearing's than a sometimes sprayed nitrous setup.
IMO, keeping an eye on the oil like I do, can only warn me ahead of time if somethign is starting to go south, and I can catch it and get the motor torn down hopefully in time before any major parts have to be replaced. By sticking to the castrol that my builder reccommends, I can do oil changed for about 16 bucks. Cheap insurance for an expensive motor for the start of it's life. I'll switch to a synthetic of the same viscosity once it's broken in, but that constant changing it will see initially will just give me a way of keeping an eye on things.
If you have to run 20/50 find a new engine builder.
Rich
Only run thick enough oil to give you good oil psi You only need 10 psi for every 1000 rpm your turning
The last ls motor I built and use 10w30 idles @ 45 psi @190 degrees after driving in 100 degree heat and maintains well over the 10 psi rule and this is a n/a car that runs rock bottom 10's.
Remember too much oil psi is just wasted horsepower robbed by the oil pump.
If you need 20w50 in an ls style motor you have some serious bleeding taking place. If your motor was built loose for a helper of some kind, that is fine but it does not have anything to do with bearing clearances, it is usually piston clearances.
Keep this in mind since you do not build your own motors, who's *** is it when the motor comes apart? I think he is the one you should ask for advice!!! If your builder will not stand behind his work, I would find a more compentent engine builder.
Good luck
my 2 pennies
Well I have just recently started running Castrol GTX 20w50 (two oil changes now) as well I change my oil every 1500 miles. but I am only putting down 499.4rwhp so I don't think I meet your requirements j/k
Biggs I suspect that I'll be well over the 10 lbs/1000 rpm rule, I am gonna run the thicker oil for one reason, that's why my builder reccommends. The motor's got alot of stuff in it that's not your normal everyday build, with the results that he's had with stuff in the past, and the fact that he's had not a single engine fail due to the way it's built, or any issues with any premature wear, I'm gonna trust him. He's built some of the fastest ls1's in the country, he knows what he's doing.
