highest compression daily driver?
Old Jul 29, 2006 | 11:20 PM
slowpoke96z28's Avatar
Default highest compression daily driver?
who here has high compression LSx engines they daily drive? post static compression ratio, dynamic if you know it, where the car is driven(ie Houston, Seattle, Detroit, etc.), timing, and hp/tq numbers
Old Jul 29, 2006 | 11:25 PM
slow trap's Avatar
i did run 11:7 scr,9.04 dcr on 93 oct with a 228r,next i will probably run the t2 at 11:88 scr 8.8 dcr.in tennessee.
Old Jul 30, 2006 | 06:59 AM
PREDATOR-Z's Avatar
11.75 SCR and 8.65 DCR on 94 octane in Summer triple digit heat. TR6 and .040 quench
No issues.
The SCR is not as relative as the DCR. Also proper plugs and quench will go a long way to facilitate high SCR combos.
Old Jul 30, 2006 | 12:28 PM
02ZOh6's Avatar
Glad to hear you guys aren't having issues. After some help from the forum I found out mine's going to be 11.56/8.66. I thought it may have been a little high for the street.
Old Jul 30, 2006 | 01:26 PM
Joel_SS's Avatar
11.3 SCR here
Old Jul 30, 2006 | 11:26 PM
ChevPower's Avatar
12.04 SCR and 8.8 DCR on 93 octain .036 quench but i run tr8 plugs in florida heat
Old Jul 30, 2006 | 11:39 PM
thats a pretty cold plug, huh?
Old Jul 31, 2006 | 12:08 AM
ChevPower's Avatar
Well i started out running tr6 on the street and 8's at the track but i got tired of changing them and left the 8's in and after about 3000 miles and not fouling one i said what the hell is it hurting other than maybee alittle NA power but i run on the bottle 95% of the time (250-350 of it)
Old Jul 31, 2006 | 08:47 AM
GuitsBoy's Avatar
Displacement plays into this too. What size motor is everyone talking about?
Now I know typically a larger cube engine will usuallyhave a bigger cam in it, which usually drops DCR. This is why you can see such high SCRs in big cube motors.
Is the drivability strictly dictated by DCR, or do the added cubes play into it? For instance would a 346 and a 402 run equally well if they were both cammed for 8.5 DCR? Assuming that heads are scaled accordingly and all else is equal.
Old Jul 31, 2006 | 09:13 AM
viewsonic's Avatar
~12.33:1 SCR | ~8.75:1 DCR | LS2 Engine | .037" - .038" quench | 93 octane | Runs in FL | TR6 Plugs | Numbers in Sig | I think I am running 27* of timing | Car is daily driven.
Old Jul 31, 2006 | 11:04 AM
ChevPower's Avatar
My set up is a 383 small bore
