Reliable 400 Hp
Everyone else will give you a different way to make that power. Its not that difficult to get big numbers and still be reliable with an LS1.
its very reliable when you not using it and if you have all the safety equipment then it will still be realiable.
but also a nice cam and full bolt-on car with a good tune will be great.
i'd rather give my money to the sponsors than to the middle east. heads can actually increase mileage, they're less damaging to the engine since they don't require as much bottom end work as big cams (i'd get heads that maintain stock compression), they make your exhaust good and loud without changing idle quality for a good sleeper, they're as close to a bolt-on as engine work gets...i'd personally rather get my heads done than a cam, but that's just me. besides, you can get a set of heads for a little over a thousand dollars, plus they come with springs, retainers and all that good stuff. with a cam you're looking at at least $600 once you buy a good spring kit. it's not THAT much more money for heads unless you get a good set like edelbrock's or AFR's. I think I can install both of them with a little help on the way. Just not sure which way to go. It's my daily-driver, running about 80miles/month in just work. Will I do fine with an average cam?
Bill
An older 221/221 would fit this bill. Add a Fast 90/90 intake manifold, and you'll see over 400 at the wheels. It will have a VERY livable idle, and will make smooth power throughout the range. Gas milage should remain excellent, and drivabiliy will not be affected.
That's the setup I'm going with, but instead of the fast 90/90, I'm going with a set of budget heads (Dart 205s).
Ben T.
